Question about Panasonic Audio Players & Recorders
Wiring assignment for plug of Panasonic SB WA340
sbwa340. I have this sub woof but no output system, manual, does anyone have the wiring diagram for the input plug from the main system to the sub. the sub also has out put for the rest of sound system
  • aaabrian
    aaabrian Aug 19, 2012
    go to hifi-manuals dot com for service manual
    New Friend:
My woofer lost the sound I.C how can i solve this problem?
Posted on Sep 22, 2011
SOURCE:
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a sb wa340 active subwoofer. I have subwoofer and speakers but I don't have DVD how can I use this
So is the DVD part missing? There is a VCR / Aux input on the back but it is for audio only. There are no video inputs so if the DVD is not included in your sub/speaker system, you'll be limited to audio only. First, you'll need to connect a TV to your system using one 'Video Out' cable methods so you can see the menu for the remote control changes on the system. From here there are 2 options:
  1. Connect up a working DVD player directly to your TV using the best option available. Use the audio outputs on your TV to connect to the VCR or TV input on the system box. (Using standard RCA cables.) You may need to enable the external audio outputs on the TV. (Check the setup -> audio menus etc.)
  2. You can use this as an audio amp by connecting a RCA cord from the a DVD R/L audio outputs to the VCR-Aux input on the amp box. You will need to run a separate video feed from the DVD directly to your TV. (Select the desired input on the TV to watch a DVD.)
You'll need to do a lot of switching back and forth with multiple remotes to get everything working, but the speaker setup can be made useful if it still works.
Here is a manual for the system: http://service.us.panasonic.com/OPERMANPDF/SCMT1.PDF
Mar 13, 2015 | Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
How can I connect the subwoofer sb-wa920 to a any audio system
Some systems have a sub out. Does this sub have an output on it? If it does, use it first from your output then out to you other speakers. Hope this helps some but I could really use more information.
Jul 13, 2009 | Panasonic SC-HT920 System
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Jun 23, 2008 | Panasonic SC-HT690 System
Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Feb 20, 2008 | Panasonic SC-HT690 System
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
1,110 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
