An E1F5 coupled with an E1F2 or E0F2 all indicate a faulty touchpad. Fixyourboard.com offers replacement Ledgestone Technologies touchpads for Whirlpool and Kitchenaide oven models. Reach out to them for more information 512-355-1108 or [email protected]
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
