Nikon D60 Digital Camera with 18-55mm lens Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D60 - Very slow shutter speed (2-4 seconds)when using the flash and pictures come our blurry. All settings are default and this is a new problem.
bhargav
Level 2:
  • Expert 66 Answers
  • Posted on Feb 12, 2010
 bhargav
Expert
Level 2:
Answers
66
Questions
Helped
22951
Points
125
Turn the dial to P mode and do flash photography this should solve it.
My D60 only when I use the flash I get an error message job nr
Job NR is usually associated with the camera's processing time during very slow shutters. If you wait long enough it will show you the image you've taken but because the shutter is very slow, the image will be blurry and unrecognizable. On manual mode or Shutter speed priority change your shutter speed to at least .125 of a second. That should fix the problem.
How slove the problem
Introduction
Specifications Recommendations
The Nikon D60 is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40 over the D60 or D40x. The D60, D40x and D40 are actually exactly the same cameras, differering only slightly in their internal electronics, but differing greatly in their prices.
The D60 is actually a D40 body with a few more card-clogging pixels, a VR lens and adaptive dynamic range, but a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40 (its default ISO is only ISO 100 compared to the D40's default ISO of 200). Its less sensitive to light because the pixels have to be made smaller to cram more of them into the same-sized sensor. Smaller pixels collect fewer photons than larger pixels. Since the D60 is half as light sensitive, the D60 has to use twice as long a shutter speed or a larger aperture, which makes it more likely to make a blurry picture than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed is invaluable for use with flash outdoors, and the extra light sensitivity in normal use will help make sharper pictures. These three cameras (D40, D40x, D60) otherwise, for most users, are identical. Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands on a D60 back in January 2008. The D60 is an excellent camera, but for most of the people who will buy it, it's the same thing as the $300 less expensive D40. I'd suggest getting a D40 and putting the $300 towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest shutter speed with flash) is more than twice as fast in the D40 (1/500 vs. 1/200), and along with the faster base ISO, the D40 is more likely to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the D40x and D40 is adaptive dynamic range. The D60 does not have any of the other next-generation functionality of the D3 and D300.
The D60 is just a D40 with more pixels, but slower shutter speeds with flash outdoors and less basic light sensitivity due to the smaller pixels needed to jam more of them onto the same-sized sensor.
I make excellent 12 x 18" (30 x 50 cm) prints from my 6 MP D40; do you plan to print bigger? Really? The resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
My nicon d60 takes longer than normal for the picture to take....like the shutter speed is too slow and the picture is over exposed . it does this on all settings
try to turn off the active d-lighting and noise reduction options at MENU
the EV should set as 0
if the problems persists, i think you should reset all the settings to default
Our D60 used to take great pictures. I only use it on Auto since most are pics of people or still objects and really I don't know to use all the settings. All of a sudden, the shutter speed is now very...
The pictures are blurry due to camera shake, which in itself is caused by the slow shutter speed. Try using shake reduction setting. To increase the shutter speed, raise the ISO rating.
My nikon d60 just started giving out blurry pictures no matter what setting it is on. The subject must be completely still to get any good shots. It use to not do this, what can I do?
A few basic checks Are you in full auto mode or some other shooting mode? Try different modes and see if any work. Does the shutter speed seem slow - like you can hear it cl - ick. When photographers want a blurry effect, slowing down the shutter is often used. Change mode or set a faster shutter speed. If none of these lead you anywhere, the imaging system that scans the imaging chip may be faulty. that's not a home repair.
When I am in action mode (with the dial turned to the running man my picture is blurry and yellow
The mode you mention above is prioritized for speed moving object such as racing, basketball game, etc...
the blurry condition is caused by the movement was too fast so the camera couldn`t capture it, the yellowish picture is caused by unmatched white balance presetting
according to my experience, when you want to capture a moment like this,
switch the dial to S (shutter) mode, set the shutter speed to 1/80 or faster, using a flash will be an advantage, don`t forget to set the white balance to auto option
hope this advice help you with your problem
Dropped my Nikon D60 now pictures are blurry and shutter moves slow
hello, mount another lens and check? this will indicate if the the problem with body or the the lens? check if af is on?
look if the mirror has got misaligned, if it has got slightly misaligned fire the shutter at slow speeds this will set it right.
hope this solves the problem
Aug 23, 2009 • Photography
Nikon D60x Blurry night pictures
Try switching to Shutter Prority (S) with a fast shutter speed.If the light is not so good, up the iso to 800 to gain that faster shutter speed..
You do not say the lens in use ? if VR, make sure its switched on or use a tripod.
Hope this helps
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
