Low sound and buzz noise from speakers when volume is turned up and a loud "hum" noise is heard from the sub-woofer.
Sub-woofer sound control varies tone.
Headphones from PC work satisfactory.
Equipment:
Dell XPS 420 Q6600 Quad Core Processor
Memory 4GB Dual Channel DDR2 800MHz (4x1024MB) Memory
Hard Drive 1TB
Single 512MB NVIDIA GeForce 8800GT card
Sound Blaster X-Fi Xtreme Gamer PCI Soundcard
19-in-1 Bluetooth Media Card Reader
Windows Vista Home Premium
Logitech cordless Keyboard / Mouse
Samsung 22 inch LCD
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
SOURCE: Not working at all
If all your connections are sound, call dell. If they can't do anything for you insist on a refund. (You have to get testy with Dell)
SOURCE: which model of xps i am searching ???
You're not running XP. You're running Windows Vista Ultimate
SOURCE: more compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
SOURCE: upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
