Borland Turbo C++ 2006 Professional Full Version for PC Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install c++ compiler in windows xp pc if already c compiler existed?
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on May 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
6250
Points
111
Un-install the existing compiler (Control Pannel > Add or Remove programs).
1helpful
2answers
How do I uninstall XP Professional and install Windows 7
If you have a Windows 7 installation disk, just put the disk in your drive and follow the instructions......it will remove your XP and install a fresh Windows 7
Crash windows xp
If the crash happens constantly you'll need a windows xp operating system disk then insert it into the CD Drive, click to Install and after you press F8 to accept the license agreement the system will search for any already existing windows xp operating sytems that are installed. If it finds your select R to repair the current operating system, this will preserve your documents, music, pictures, videos and programs.
3helpful
2answers
How to reformat os of windows xp
> Put the Windows CD in your optical media drive and Restart you PC.
> It would say that you have to press a button/key in order to boot from your bootable CD, do so by pressing any key on your keyboard.
> PC would load the required files from the CD and you'll be presented with menu from where you can either Install, Repair your already existing Windows Installation.
> If you want to fix something on your PC Repair will be thew right option for you but in case you are really willing to Format and Install your Windows from scratch select Install. Windows will show you that you have already an instance of Windows present. Ignore it and move on, in the next menu you'll be able to delete and format partitikons on your HDD.
> Format C: as it is the partition which holds the operating system.
>> I assume you are using Windows XP or above.
1helpful
Hi i purchased lenovo nottebook G560 with config. 4gb ram, 320 gb HDD, intel i-3 processor and windows 7 home 64 bit. i tried to install turbo C compiler on my laptop but it didnt. i also want to install...
Hi
1.There you have a 32bit version of the compiler try to use the 64bit version
2.Install Windows XP to another hard disk and select the appropriate operating system via a windows boot menu
2answers
How can i install visual basic 6 on the windows 7
please get the new version of the visual studio ... the visual studio 6 is not compatible with windows 7
1helpful
2answers
How to reformat a pc?
Please go through the below instructions, I have sent you the instructions for how to reformat a PC /laptop and I hope this will help you in understanding as well as learning.
If you have windows XP, 95, 98, or ME:-
How to Format a Computer with Windows XP:-
  1. The first step in learning how to format a computer with Windows XP or 2000 is to insert Windows CD and restart your computer.
  2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.
  3. At the Welcome to Setup page, press ENTER.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
  7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
  8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
  9. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
I have no clue which windows are you using ,i have sent you one post for Windows XP and will also sent you the post for Windows 95,98 or ME.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
I can't isntall turbo compiler on my computer
becose of your software is besed on xp u need vista based tc
2answers
Explorer.exe Application Error in Windows XP Professional SP2
Bring a bootable XPSP2 cd & boot from it ....when installling choose C: & format ..
5helpful
2answers
Not possible xp installation
How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
(Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
Follow these steps to install Windows XP on your Vista machine:
  • Insert your Windows XP install/recovery CD and restart your computer.
  • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
  • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
  • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
  • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
Top Borland Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
