Your display is actually reading "SAB". This is an indication of a mode of operation rather than an error code. The following link explains:
http://www.fixya.com/support/r3608491-sabb_or_sab_explanation_kitchen_ranges
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features and operator, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 3 seconds to clear the Sabbath Mode. "Sab" will flash for about 5 seconds, then return to normal display.
If you can't find this information, or no longer have an owner's manual, please post back and let me know. Please include your MODEL NUMBER ( if different from the one you posted this question under) when posting questions, so that we may be able to provide yo with better service. I hope this helps you.
Very useful and a quick 65 dollars. plus you saved a nice old lady 250.00 for a new board - cheers
my sincerest thanks to you sir. Almost spent many dollars to have a repairman come and fix the sab 'error code"
Thank you, almost bought a new range
Thank you. Very clear and helpful
Problem fix thanks very much tou save me a lot
SOURCE: Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control
or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
