Question about JVC Everio GZ-MG37 Camcorder
JVC Everio GZ-MG37u Cant Connect to Pc
Hi!
My PC can not detect my digital camcorder. The model is the JVC Everio GZ-MG37u. When I bought the camera, it did not have the USB connector. I used the USB cable of my portable hard disk drive which has a mini-usb connector at one end.
I checked the manual and all it said was connect the camera with the usb cable and turn it on and the computer should be able to detect it. I set the camera to the record and play function and it could not be detected.
My PC uses Windows XP service pack 2.
Hope you can help me
  • 4 more comments
  • cthompson Feb 25, 2008
    I ahve a JVC Everio GZ-MG360BU and I loaded the cyberlink software just as the tutorial stated. I connected my Everio to power and then I connected the usb cable to my PC. I opened the view screen and the backup and playback options apear. I select backup, but my PC is not recognizing the Everio. I then selected Power Cinema and selcted backup and it states the no Everio was detected. I then selected my computer and it doesn't recognize the device either. Please help.
  • mitts Jul 21, 2008
    I am having troble with my computer reconizing my camcorder with Neno we are able to view but it wil not let us save file on computer please let me know what I need to do.
    Thanks
  • jglg14 Jul 25, 2008
    HAVE THE SAME PROBLEM my jvc wont commect to pc? what can i do
  • Patring Oct 17, 2008
    JVC EVERIO Gz-mg37u cant connect to pc...
  • Streetstride Dec 07, 2008
    Me too can anyone help?
  • Anonymous Dec 17, 2008
    my computer does not find the camcorder
How to export video from camcorder to windows movie maker because power producer sucks!!!!!!!!!!
Posted on Jul 12, 2009
I have the same model, gz-mg 37u and my computer won't recognize it either. There is no docking station for this model. Any other advise?
Posted on Dec 08, 2009
The camera must be "on" before you plug in the usb connector or there is nothing for the computer to find.
Set the switch on the camera to 'playback' before you plug in the usb cable.
Posted on Aug 24, 2008
I don't have a docking station - just the usb cable and the Everio. Why will this not work?
Posted on Jun 07, 2008
I have a m365 that wouldn't get recognized by the PC properly unless the usb cable was connected to the doc. The dv connection alone wouldnt make the camera present me with the intial menu to choose playback on pc/backup/etc.
Posted on Jun 02, 2008
Hey guys, i had a very similar problem with the everio. The solution for me is that the camera didn't sit properly in the docking station causing the camera and pc to stop communicating. What worked for me is to firmly push the camera into the docking station until the pc finally picks it up. Now i have no problem with the device.
Regards
Dan
Posted on Mar 14, 2008
2 Suggested Answers
SOURCE:
SOURCE: JVC Everio GZ-MG37u Cant Connect to Pc
I want driver sony handycam 700x digital 8
Posted on Sep 19, 2008
I need a user manuel for a jvc everio hdd 30gb camcorder model gz-mg37u
You can download the manual from the manufacturer's web site at
http://resources.jvc.com/Resources/00/00/91/LYT1533-001D.pdf
Mar 21, 2011 | Cameras
I have JVC Everio GZ-MG630AU camcorder and when I connect to my computer, it just says USB Device Not Recognized. I have Windows Vista and have tried all of my USB ports to no avail. My email is...
Please check the camcorder with another PC so as to confirm the hardware in the camcorder. If this is not detected then there are errors in the camcorder main processing section which is not interfacing with the external port.
however if the camcorder works with another PC then it is possible that you PC has to be reinstalled with the OS and the drivers.
Feb 05, 2011 | JVC Everio GZ-MG130 Camcorder
Lost cd-rom to install software for the jvc gz-mg37u hard disk drive
Required software cd-rom is available in JVC Accessories Store for $31.90
under following part number:
CR-ROM W/CAPTY MPEG EDIT LY35273-002A-S
Jun 03, 2010 | JVC Everio GZ-MG37 Camcorder
How can I recover a file from a JVC Everio GZ-MG37U
First things first: DO NOT take any more videos or pictures with the camcorder(memory card) that you want to recover files from in case you may quite possibly ruin your chances.
Then take the memory card or hard drive out of your cam, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
For Windows Version
For Mac version
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your files safely!
Oct 07, 2009 | JVC Everio GZ-MG360 HDD Camcorder
I have a JVC GZ-MG37u Everio. It is a harddrive and its full. I need to get the videos from my camcorder onto a dvd that will work in any dvd player. Is it as easy as hoooking it up to my dvd player and...
hook it up to the front sockets on your dvd recorder ..select the front imput sockets on your dvd remote usually av3 press play on the camcorder and record on the dvd recorder.or hook it up to your pc to edit...
Sep 14, 2009 | JVC Everio GZ-MG130 Camcorder
JVC GZ-MG37U with CU-VD10U Station
WHAT EVER TYPE YOUR PC CAN BURN THE EVERIO HAS A HARD DRIVE IT DON' USE DVDS
Sep 20, 2008 | JVC Everio G Camcorder
Drivers
i lost the cd driver for my gz-mg37u jvc hard drive camcorder what shall i do?
Sep 20, 2008 | JVC Everio GZ-MG27 Camcorder
Sep 17, 2008 | Video Cameras
JVC Everio GZ-MG135E
I bought the JVC model MG135AGM but i dont have the driver. My problem i cant view my video w/o the software driver. where i can find it or download the driver
Apr 20, 2008 | JVC Everio GZ-MG130 Camcorder
JVC Everio GZ-MG37 Camcorder Logo
9,231 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
