PHILIPS 42PFL7662D/05 FAULT. Blank screen, totally black but with perfect sound. Girlfriend reckons she heard a pop when she turned the tv on. Any ideas?
Main system control memory IC is faulty. It should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Try with that... http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom: Sound but no picture.
Cure: Master or Slave inverter is defective. It can be that the driver IC is defective or MOSF inverter transformers, or 470uF 35V C Replace driver IC BD9897FS or MOSFET's. 996500046243 IC BD9897FS 996500046242 Mosfet FDD8447L 996500046241 Zener KDZ100V
We have the same telly and had the same problem. Ours was bought Jan 08. It can be repaired, as we had ours returned from the philips repair specialist yday, but it cost £190.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
