Washer will fill but stops wont agitate.It will rinse @ spin whe I turn the dial.I have heard if washer spins all right ,then it cannot be the lid switch. Is this true.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
