My hotpoint aquarius dc26 dishwasher has stopped working, it is 8 years old. When you start any of the cycles the pump starts but no water comes through to start the wash.
This may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
