Televison & Video Logo
Posted on Feb 11, 2010
Tv turns on but no picture but has sound and menu
Tv turns on but no picture but has sound, and menu display and channel display still work I dont know what model rca this is but its very large and square.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
876
Points
55" rca projection tv turns on has sound but no picture
2answers
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
1helpful
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
8helpful
2answers
Sound problem
when you mail me,i have an service manual for you
[email protected]
I have a 1999 big screen purgation mitsubishi tv and when i turn it on it go's to this ant-B and under that it would say stereo SQV and i can hear the show that is playing from the cable box but it dont...
If you go into the Main Menu for the TV with the Remote, then into set up, look for a adjustment that says Monitor or TV.
It sounds like it is in Monitor mode.
Hope this helps,
Skyassoc
8helpful
No sound on analog channels
Grab your sharp remote and press MENU, arrow over to SETUP, arrow down to RESET and press enter and follow that prompt to reset the unit. Once that is complete turn the tv off and unplug ONLY the tv for one minute then plug it back in. Then turn the tv on and see if you have channels, if you do, your audio should work on you analog stations, if you have no channels and all you see is a snowy picture do the following press MENU, arrow over to SETUP...arrow down to CH SETUP and press ENTER...you will then be at a screen that says AIR/CABLE, press ENTER, select CABLE or CABLE(STD) if that option is available to you. after then, arrow down to CH SEARCH, press ENTER, then you should be highlighted on ANALOG AND DIGITAL SEARCH...press ENTER and wait for 15-30 minutes ( or until you get a picture back) and make sure you DO NOT press any buttons or turn the tv off and you should be good. good luck 2 u
2answers
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
15helpful
2answers
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
