Please allow me to help you with you
Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue
tooth on your phone.
2. The phone should find the
Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all
blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using
Fixya.com "We have a solutions for everything"
I hope this
solution was VERY HELPFUL!
Have a Great day
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have the same problem my motorola H500 won't hold a charge, I have tried charging it over and over again, NOthing. I have had it a couple of months and can't return it. What do i do? trash it?
