Hotpoint Aquarius WF000 Front Load Washer Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aquarius wf440 is tripping rcd tried the element but reading 34ohms
Paul Woodward
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Sep 22, 2015
Paul Woodward
Expert
Level 2:
Sergeant:
Answers
200
Questions
15
Helped
56463
Points
923
Have u checked that the thermostat is ok? aka thermistor, use a multimeter on resistance and a hairdryer to watch resistance go up and down, if it doesnt replace it. its often a little round thing near element with 2 spades showing.
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Feb 11, 2010
Anonymous
Expert
Level 2:
Answers
56
Questions
Helped
20177
Points
139
Remove plug from socket . and then remove motor plug if your able from motor .and test motor .
Neff U1422 oven grill tripping RCD
The grill element has an internal short and needs replacing. Sometimes you can see it as a slight bulging of the element. This happens just before it blows a hole. It may also have been physically damaged when something was put in there after a few Sherries. :>D Sounds like your RCD is adequately sensitive.
Jan 02, 2024 • Neff Ovens
1helpful
Trying to repair a belling model no. 444449577, bottom oven fault. Any adjustment on the oven temperature control trips out the main RCD. Suspect element burnt out. But physically it looks OK?
Check for short to ground or for no resistance on heating element with DVM "Digital Meter" If meter is not available try this - With circuit breaker turned off disconnect wires to bottom heating element - put caps on wires or otherwise islotate the connections from any metal. Turn breaker back on and adjust temp on oven if RCD does not trip then the element is bad "Shorted" replace element. Element can be shorted to ground or shorted internally. Additional information at this link "https://www.6ya.com/philip_b05beb373d913f26"
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 • Ovens
Oven trips RCD
Check for loose connections on or near the element. Heat form the element could be causing the connection to expand causing arching and tripping the MCB.
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
1helpful
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
Washer/drier tripping rcd!
Hi.
Sounds like you have a short or an earth fault.
if it trips right away, try it with the motor disconnected, if it still trips then you will probably have to call an engineer..
2helpful
Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
2answers
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
