Security code
The security code (5 to 10 digits) helps to protect your phone against unauthorized use. The preset code is 12345.
To change the code: PAGE 65http://nds1.nokia.com/phones/files/guides/Nokia_6070_UG_en.pdf Restore factory settings
To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett..
Enter the security code. The data you have entered or downloaded are not deleted, for example, the names and
phone numbers saved in Contacts
HOPE THIS HELPS
ALAN
hi restore the factory setting of the phone 1)go to menu 2)Setting 3)setting 4)general 5)factory setting (enter the phone code.default code is 12345) or if doesn't work try to hard format the ph memory by dialing *#7370# as there is nothing important in ph memory (NOTE--Bro before hard format pls back up ur phone memory contact as it will delete all the data in phone memory including installed applications in ph memory)
Hi, standard master reset code for nokia is 12345. But if fails, you can get the code here for FREE*) : www.nfader.su Best regards, Jay *) need to key in your IMEI #
make sure you used correct usb cable, Download Phone Manager, go directly to download phone manager software, this is free. Also make sure phone configuration setting ready, if no, ask your network provider for configuration setting.
if security code is not default or standart etc: 12345, 0000 you need tool box to do that. you can use UFS, JAFF. With this tool you can read the scurity code or you can make scurity to default
