Panasonic PV-D4752 DVD Player / VCR Combo Logo
ronald hubert Posted on Feb 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Digital TV does the panasonic dvd/vcr deck model #PV-D4752 have a tuner built into it and if so, is it a digital tuner? If it has a digital tuner, will that receive the new DTV broadcast signal without a converter box?
Anonymous
Level 2:
Sniper:
  • Expert 67 Answers
  • Posted on Feb 23, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
67
Questions
0
Helped
204537
Points
257
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A rel='nofollow' href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
2helpful
2answers
Remote codes for Panasonic MODEL# PV-DF2704
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
1helpful
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 • LG LRY-517
Owners Manual for Panasonic VHS- DVD Player, Recorder Model PV-4734S Ser# G41A44492. e-mail [email protected]
Post your query to the following site ;
www.myproductmanual.com/???manuals/???panasonic www.devicemanuals.com/.../Panasonic/Panasonic-PVDR2714-TV-VCR-DVD-RECORDER-TWpFMU13PT.html · Cached page
Sep 27, 2010 • Cameras
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
1helpful
We have an older tv without Audio/video jacks, we want to hook up a VCR/DVD that has a built in tuner, we also have a cable digital box, I know we need a RF Modulator. Is there a way to hook this up so we...
If you have a main aerial,plug it into the vcr then take a male to female fly lead out of the vcr into the tv.You then need to tune in the tv to the vcr and then tune in the vcr.
ARE MY PANASONIC PV-DM2799, AND MY PANASONIC PV-M2737 BOTH DIGITAL READY, AND ONLY NEED A CONVERTER BOX TO RECEIVE PREMIUM CHANNELS....THANK YOU VERY MUCH
You can get a converter box for these for over the air programming but if you got satalite or cable you are FINE!!! it will work great
But they do not have digital tuners no.
Please do rate the answer thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
