Computers & Internet Logo
Anonymous Posted on Feb 11, 2010
MCP61PM-HM mobo won't run long enough for os to boot
Replaced original mobo and processor (exact). shows proper memory, drives.
shuts down even if still in bios setup after a minute or two. even when disconnected all drives, usb. removed battery and reset cmos. used new thermo grease. processor doesn't seem very warm.
am i missing something!
  • Anonymous Feb 11, 2010
    originally I did not reset processor exactly correct.
    (found AMD processors a little tricker than intel)
    i removed the battery and used the jumpers.
    tried it a second time and left the battery out. went much further in the os boot process. but did shut down prematurely.
    will probably return the board to the vendor.
    Thanks.
Anonymous
Level 3:
Genius:
  • Master 1,288 Answers
  • Posted on Feb 11, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1288
Questions
Helped
285790
Points
4123
I'm assuming you didn't use the Cmos jumpers to reset the cmos and only replaced the battery?
Checked board to see if there are any capacitors bulging, leaking r blowing?
You don't say why you removed it in the 1st place? I'd remove it again and test it outside the casing, see if that solves the problem, then look inside the casing to see if there is anything that could be causing a short,
Other than that, you may have damaged a component on the board when you originally removed it
Putting a hard drive on the HP MCP61PM-HM. Want to do this step by step includin hooking up the fan, motor memory chips,etc.
just hook everything up the way it is supposed to and get out your OS disk and load it. Then get the drivers needed and you are good to go.
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
1helpful
Need manual for my motherboard
Any idea of what desktop computer it came out of?
My intel states it is an ECS (Elitegroup Computer Systems) MCP61PM-AM mobo, made for Gateway/Acer desktop computers,
(Acer bought out Gateway), Packard-Bell, and other desktop computer manufacturers.
Stating;
1) HT 2000
HT stands for Hyperthreading Technology. Used by AMD and Intel.
Using 2000 along with HT, denotes it is an AMD processor using HT.
Processor can move data back, and forth, up to 2000 MegaTransfers per Second. (2000MT/s)
2) MCP stands for Media and Communications Processor.
Nvidia's Northbridge, so to speak,
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Recent Developments;
"Another example of this kind of change is Nvidia's nForce3 chipset for AMD64 systems that is a single chip. It combines all of the features of a normal southbridge with an AGP port and connects directly to the CPU. On nForce4 boards they consider this to be an MCP (Media Communications Processor)."
The Nvidia MCP61 is the GeForce 6150SE,
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6150SE
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
The PM stands for Post Meridian. The AM stands for Ante Meridian.
In otherwords good for Night to Day.
Just some gobbelity-goop the mobo manufacturer added.
Is it an ECS MCP61PM-AM mobo? (MOtherBOard),
http://www.ascendtech.us/ecs-mcp61pm-am-dual-core-am2-motherboard_i_mb64ecsmcp61pma.aspx
Scroll the page down.
At any rate, what info do you need?
What Ram Memory is used, and how much?
What the pinout is for the Front Panel header on the mobo?
What Processors can be used?
Please state in a Comment.
Regards,
joecoolvette
[By the way. If it is out of a Peckerd Bell computer, I find them LESS THAN. Support for a user? Sure for $$$$$$ ]
3helpful
Have a motherboard in my computer that stopped working. It is MCP61PM-HM 2.2. I ordered a new motherboard only to find out that the one I ordered was MCP61PM-HM 1.0B. My question is are they compatible?
Seems like the 2.2 is a new version. It supports a
  • Phenom with Quad Core technology (AM2+) up to 9600 (up to 95 watt)
  • The link below has the specs of your original MOBO...
    http://www.softunique.com/ECS-MCP61PM-HM-Nettle3-GL8E-Motherboard-HP-ver-22-MCP61PM-HM-V22.htm
    Here are the 1.0B specs:
    MCP61PM-HM REV:1.0B SOCKET AM2 MOTHERBOARD
    Motherboard description Motherboard manufacturer's name: ECS MCP61PM-HM
    HP/Compaq name: Nettle-GL8E
    CPU/Processor Socket: AM2
    Supports the following processors:
    Athlon 64 X2 with Dual Core technology up to 5600+ (up to 89 watt)
    Athlon 64 less than 4000+
    Sempron less than 4000+
    Front-side bus (FSB) 2000MT/s (2.0 GT/s)
    Chipset NVIDIA GeForce 6150SE nForce 430
    BIOS features System BIOS core brand: Award
    Keyboard combination to used to enter BIOS: F10
    Form factor Micro-ATX: 9.6 in X 9.6 in
    Memory Dual channel memory architecture
    Four 240-pin DDR2 DIMM sockets
    Supports PC-4200 (533 MHz), PC2-5300 (667 MHz), and PC-6400 (800 MHz) DDR2 DIMMs
    Non-ECC memory only, unbuffered
    supports 2GB DDR2 DIMMs
    Supports up to 8 GB on 64 bit PCs
    Supports up to 4 GB* on 32 bit PCs
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Acer aspire 7520g will not boot
    Your reflowing of the mobo did the troubleshooting for you. Your mobo is bad and most likely needs to be professionally reflowed. The problem with the ACER in particular is not knowing exactly what chip is the bad one. I know for instance the chip on an HP board is usually the Nvidia chip which does many things for that system. The blanket trick works more as a diagnostic tool than actually fixing the board for good. You are probably in a position to either reflow your board or replace the thing. Good luck
    Dell PowerEdge 1600sc server won't boot.
    > black screen & flashing cursor ...
    Damaged boot-record on the disk-drive???
    Was it configured to try to boot from 'A:' ?
    Disconnect the hard-drive & CD/DVD drives.
    Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
    If it tries, then it has P.O.S.T.'d correctly.
    > no beep codes
    When it worked, did it beep _once_ when P.O.S.T. completed?
    Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
    > anyone?
    Replace the monitor?
    Replace a dead video-card?
    Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
    1helpful
    Replacing a mcp61pm-hm nettle2 mobo in my hp forgot wire placemen
    The little white plug sounds like the audio connector. Most usually you do not have to hook this wire up. The sata connection from the drive to the mobo should take care of everything. Most usually this plug in is for connection directly to a after market sound card. The little black plug coming from the media bay you speak of sounds like the front side usb connector. It may also include the front mic and headphone jack. Please check to see if the black plug actually attaches to the front of the pc near the power buttons.
    2helpful
    2answers
    My HP Compaq Presario v2000 has new mobo, new CPU
    You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
    gurutim
    2answers
    Computer shuts off
    go to the bios then check, your processor deatials
    114helpful
    7answers
    HP MCP61PM-HM motherboard diagram
    Hi RobPu,
    I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
    ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
    http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
    But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
    Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
    For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
    daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
    Try it, I'm sure it will work for you.
    Enjoy!
    If I can help you further, feel free to post.
    Suggestions & comments welcomed.
    Mike
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
