Zebra Eltron TLP 2844 Thermal Label Printer Logo
Posted on Feb 10, 2010
Just one of the double tags is printed on
My Zebra LP 2824 prints only on one of the double tags
lancer284
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Feb 16, 2010
lancer284
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
18581
Points
55
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
  • lancer284 Feb 16, 2010
Lp 2824 plus won't print. Have windows 7 till switch off and on again
printer driver conflict or windows 7 driver incompatibility. contact zebra for proper driver installation.
Zebra eltron LP 2824 printing too light
This could simply be old direct thermal labels. Direct thermal labels have a shelf life of about 1 year from the date of manufacture. After that time has lapsed the thermal coating on the labels begins to dissipate and this will cause labels to print light or faded. You can trouble shoot with a roll known to be fresh. You can get one free here to test Labeldomain com .
If this does not solve your problem then please check this article on 5 common print quality issues and how to correct them Fix Zebra 2824 2844 3842 print quality
3answers
My lp 2824 zebra printer is printing too light
I am unsure if this one is a ribbor printer or a thermal......
if thermal the paper might be too old or the print head is going bad. if ribbon try replacing the ribbon, or you have a bad batch of ribbons.
1helpful
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Our LP 2824 Zebra printer stalls with red light when printing labels. Tried calibrating but it stalls with solid red light before printing out data
Try another roll of labels? If that doesn't help, it may have a problem with the sensor that checks the starting point of the label. These are old so it's easy and cheap to replace with a similar unit.
Tags cannot be printed properly in QB POS Version 8. Printer Argox OS 214-TS
The tag printer used by Qb POS is the Zebra LP 2824.
The argox is not compatible.
Labeller not printing in black - appears to be white
possible the ribbon is on the outher way.
The darkness is to low.
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
