Question about HP Compaq Presario CQ50-110US Laptop
Screen flickers unless I press on the speakers.
The screen on my Compaq Presario CQ50 flickers and rolls, but now when I press down on the left speaker area right above the keypad. I assume that this is a problem with the screen inverter or just a lose connection inside. Any help would be very appreciated.
    New Friend:
  • 56 Answers
This might be a easy fix for you most likely it is that the cable has come loose which with this model they are known for this. The cable for the LCD is in the left corner. If you need help with get back in contact with me.
Posted on Feb 10, 2010
6ya staff
SOURCE:
Cq50 flicker
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
If not fixed:
Please scan your computer with free version of superantispyware:
http://www.superantispyware.com/
IF not fixed: It is a screen hardware issue.
Jul 09, 2013 | Compaq Presario CQ50-215NR Notebook
Sir My CQ 40 144 TU Compaq notebook screen flickers many times when I turn on the system and move the screen to and fro. At only one particular position it does not flickers. Please tell me a solution to...
that may indicate that something is wrong probably with the inverter board. its a hardware issue and may require you to have unit dismantled and checked.
regards
Mar 24, 2011 | Compaq Presario CQ50-215NR Notebook
My Compaq 14" laptop (LED
does it keep flickering? If so, there is a small circuit board in the top below the screen that can go bad, resulting in your screen eventually going dark---I had to use a flashlight to see anything. I would have it checked by a service tech soon.
Feb 14, 2011 | Compaq Presario CQ50-215NR Notebook
Laptop screen flickering CQ50-110US
unseat and reseat the LCD cable behind the LCD and also where it connects to the motherboard. If that doesn't solve it, then try another lcd cable. If that doesn't fix it then that means the LCD is bad and would need to be replaced.
Apr 19, 2010 | HP Compaq Presario CQ50-110US Laptop
The screen rolls and flickers on my Compaq Presario CQ50. Is there a fix for this? It is getting progressively worse.
your might need a new screen, or if your using windows aero, or windowblinds that could do it. also ther could be something like a virus thats making your system buggy
Apr 02, 2010 | HP Compaq Presario CQ50-110US Laptop
Compaq Presario CQ50 Comes on but the screen is very dark!
The Presario's have an intensity control for the screen.
Mine is holding the function button (Fn) down an pressing F8 for brighter, F7 for dimmer.
The marking on my F7and F8 show an asterisk indicating "sun" for intensity.
Jan 11, 2010 | HP Compaq Presario CQ50-140US NoteBook
I have a compaq presario cq50 215-nr. the lcd screen constantly flickers with colored lines going top to bottom. I can work if I press the screen down. I called HP they say that this comes under accidental...
I am sorry to tell you that the screen has been damaged and will need to be replaced. There is no work around/solution for a bad screen. Replacement is the only way to go. Sorry.
Sep 06, 2009 | Compaq Presario CQ50-215NR Notebook
FS050UA , COMPAQ PRESARIO NOTEBOOK PC CQ50-210US the screen has lines and a black spot
Turn on the notebook and press F10 to get into BIOS screen. Even if the lines and the black spot appears then the issue is with the internal hardware of the notebook.
To check further connect an external monitor to the notebook and press Fn and F4 keys on the keyboard to get the display on external monitor. If the external monitor display is fine then the issue is with the LCD screen or else the issue is with the Video card of the notebook.
Jul 31, 2009 | HP Compaq Presario CQ50-210US Notebook
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
HP Compaq Presario CQ50-110US Laptop Logo
380 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
