Konica Minolta Pagepro 1350 page count or Print Config sheet?
How do you print or get the page count / print count total for a Konica Minolta pagepro 1350? Trying to find information on printing a status or print configuration sheet?
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
the risk of damage to the product, KONICA MINOLTA BUSINESS TECHNOLOGIES, INC. (hereafter called the KMBT) strongly recommends that all servicing be ...Missing: we
PagePro is a trademark or registered trademark of KONICA MINOLTA. PRINTING .... Print Media 20. What Sizes of Media Can I Use? 20 .... Stop/Reset key. Exits the menu. ... Right-click the KONICA MINOLTA PagePro 1390 MF printer icon.
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
the problem it might not be the printer. I encounter this problem before. the solution is uninstall the print driver to the control panel and re install the print driver using the cd print drive or you can download to konicaminolta web site..
