Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
