My speedometer doesn't work and my fuel gauge works sometimes and my odometer doesn't work at all either for my 2000 Yamaha Roadstar Silverado
SOURCE: how to set electric clock on 2003 yamaha roadstar silverado
Hold both buttons for approximately 5 seconds until the time starts flashing. Then using the right button change the time and use the left button to select minutes or hours.
hold both buttons down @ same x. they will start to blink. hit left button once and hour will blink. use right one to go up. repeat for mins.
check the fuse pos under the panel
SOURCE: speedometer works somtimes,2002 yamaha roadstar
make sure all your connections are tight from the speedo (sqaure plastic ) if they are your speedo sensor may be bad
SOURCE: yamaha roadstar 1600 yr.2000 digital
The first thing you can do is check the fuses, the fuse box is either under the seat or behind the cover on the left side as you are sitting on the bike, if all is good then remove the speedo cluster and connect it to your battery directly, Here is the procedure from the manual CHECKING THE LEDs The following procedure applies to all of the LEDs. 1. Check: LED (for proper operation) a. Disconnect the meter assembly coupler (meter assembly side). b. Connect two jumper leads 1 from the battery terminals to the respective coupler terminals as shown. WAWRNARINNGING • A wire that is used as a jumper lead must have at least the same capacity of the battery lead, otherwise the jumper lead may burn. • This check is likely to produce sparks, therefore make sure that no flammable gas or fluid is in the vicinity. c. When the jumper leads are connected to the terminals the respective LED should illuminate. Does not light ® Replace the meter assembly. This will tell you if it is the meter, If the meter is good then you will need to follow the wires connected to it till you find the problem. I hope this is a big help to you.
7
