same problem starts up then asks for update or to format the devicesame problem starts up then asks for update or to format the device
AnonymousFeb 27, 2008
hi just took my new archos 605 out of the box and when i power up it tells me that I have an error 104 ??!!Its brand new for god sake tried to download the file from archos but it doesnt do any goodhi just took my new archos 605 out of the box and when i power up it tells me that I have an error 104 ??!!Its brand new for god sake tried to download the file from archos but it doesnt do any good
Yeah, and when u choose any of this options , it restarts and does the same thingYeah, and when u choose any of this options , it restarts and does the same thing
so i turn it on and asks to repair system. i press repair disk, it says to connect to the pc and install an update file, but there is no link to the pc and i dont know where to get the update file that i need??
It just works one time after doing that "solution", then does the same thing next time you turn it on.It just works one time after doing that "solution", then does the same thing next time you turn it on.
Can anyone give me EXACT instructions?I have the "Recovery (code 102)" problem.
How to install that update.
AnonymousFeb 10, 2009
I bought my 605 brand new, it worked one day, now it has "recovery(code 104) and every time I have it plugged in, it says to make sure that it is not a read only file...help?
i just got the firmware but idk where to put it do i make folders or something? i just got the firmware but idk where to put it do i make folders or something?
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Try the steps below:
1. Select 2nd option "Repair" or 3rd "Format the disk"
2. Connect 605 to PC using USB wire and find the Driver named "a605" or similar words
3. Copy a firmware to the ROOT directory on the driver mentioned above
4. Keep the USB connected and select "OK" on 605
5. Re-calibrate the screen under Display menu on 605.
Just a little FYI: hotlyq's solution works just fine, but the firmware file needs to be name exactly as it is downloaded. I downloaded both OSv2.1.0.4 and OSv2.0.1.0 firmwares to the same folder on my PC. Obviously enough I had to give them different names on the disk, I tried both and neither worked. It turns out the recovery system will not use any firmware unless it is named "firmware_a605f.aos". So if you're like me, copy the firmware over to the root of the USB-drive and then rename to firmware_a605f.aos.
Get update first have ready,on archos go to format disk it will then show the drive on your computer open and drag the update in the window.Do not put in folders of music,pictures or movies by itself only.Eject and OK button on archos and your good to go.
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted. With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk". Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
Some machines have a recovery partition installed on them to start this as the machine is starting up hold down alt and then tap F10 and it will start the recovery partition.
If that does not start one however you will need to use the recovery disc that came with the machine or you made when you first bought the machine. If you do not have one you can call Toshiba and request one to be sent to you. They are required to send you one if it is requested.
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
it will come up with white screen again but this time it will start
Update you will see the progress bar moving wait until it is all done
and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
If you chose any of these options already your Os is gone..
try this solution
(104) on it. This might work for other error codes too. These are the steps i
followed * Use thecomputerfor this
process that you always used for this archos Archos should be plugged in to Pc
before starting the process. * Download the firware Upgrade 2.1 * Plug the Archos toPc * When the white option screen comes up pick the
format disk * Wait until all done do not pick any option on
archos after format is done Pc should recognize your archos in 5 seconds * Put the firmware in root section of the archos not in any folder. * Safely remove the usb for Archos from your pc
first and then unplug thecable. * Do not pick any option on the Archos screen * Just turn it off from the power button by
holding it until it turns off * Wait about 5 minutes and plug it back to pc * it will come up with white screen again but this
time it will start Update you will see the progress bar moving, wait until it
is all done, it will shut off. Turn it back on and your archos will be back to normal
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed * Use thecomputerfor this process that you always used for this archos Archos should be plugged in toPc before starting the process. * Download the firware Upgrade 2.1 * Plug the Archos toPc * When the white option screen comes up pick the format disk * Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds * Put the firmware in root section of the archos not in any folder. * Safely remove the usb for Archos from your pc first and then unplug thecable. * Do not pick any option on the Archos screen * Just turn it off from the power button by holding it until it turns off * Wait about 5 minutes and plug it back to pc * it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and your archos will be back to normal
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
go to archos firmware and download version 2.1.04 to your pc or laptop and save it in a folder then get ur mp4 turn it on and go format you will get a screen that says done leave it on that and connect to your pc or laptop it will recognise your mp4 then go in my computer and open 405 and open your save file and drag the save file into the 405 but NOT into a folder below them and after it has\copied turn the 405 off and start it up should be as good as new
esto es tremenda mierda
recovery code 104
recovery code 104 ivebeen stuck for months its driving ne crazy
