OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is problem with my cummins generator the is
There is problem with my cummins generator that is not taking speed, rpm are not getting high, generator starts but with low rpm.there is electronic fuel pump and pcc 2100 moduel.plz tell me what to do?
Starlight Power
Level 2:
Sergeant:
  • Expert 117 Answers
  • Posted on Mar 06, 2018
Starlight Power
Expert
Level 2:
Sergeant:
Answers
117
Questions
0
Helped
96246
Points
657
Maybe you have solved your problems. But I still like to share some useful methods to deal with generator problems. Useful articles as follows:
Simple ways to deal with diesel generator failure Simple Ways to Deal with Diesel Generator Failure
Why diesel generator fail to start Why Diesel Generator Fail to Start
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Feb 11, 2010
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
7364
Points
32
Check fuel filter it may be only getting enough fuel to run up to so many rpm
4answers
Check engine ecu light keeps comming on 2006 volvo
Get OBD (on board diagnostic) from auto zone and plug it into car to read error codes.
2answers
Cummins generator starts but no power
Cummins generator set will occasionally encounter generator failure in the process of use that Cummins generator set is not generating electricity. What is the cause of it? And what to do about it? In fact, there are a lot of reasons that Cummins generator set is not generating electricity.
1. Wrong connection of generator set. Processing: check and correct by wiring diagram.
2. Generator speed is too low. Processing: measuring speed and keeping it at rated value.
3. The connection between the stator winding and the generator distribution equipment has sludge or oxide, the connection screw is loose, the connection wire is broken, and the stator winding is broken. Handling: use a multimeter or lamp test method to find out where the wire is broken. Check the connection and contact of each connection screw.
4. Excitation circuit broken or bad contact. Processing: use multimeter to identify broken wire and reweld the broken wire to bind insulation.
5. Rectifying tube (including rectifier diode, thyristor) is damaged. Treatment: replace damaged parts.
6. Brush contact with slip ring bad or brush pressure is not enough. Treatment: clean the surface of the slider ring, polish the brush, make it match with the surface of the slider ring, increase the brush pressure.
7. Brush grip rusts, brush can not slide up and down. Treatment: wipe the inner surface with a cloth brush, if damaged, should be replaced.
8. Cummins generator exciter brush position is incorrect, brush damage or spring pressure is not enough. Handling: adjust the brush to the correct position, replace the brush, adjust the spring pressure.
https://www.dieselgeneratortech.com/cummins
Oman 6.5 watt generator in 1986 winnebago does not run at normal speed
This is called hunting and it is because the load sensor is not working
2answers
My 1000kva cummins generator shuts down during operation indicating low voltage. what is the cause
Check for floating debris in fuel tank possibly restricting fuel flow thru screen on bottom of fuel pickup;
I have a generac 22kw model QT02224anan that will run for a few minutes then shut down , then the over speed led is lit. It only happens when it is under load or during a power outage. it goes through...
its possible the overspeed is set to sensitive. or your rpm are to high. these are preset in the factory as a safety, check your manual to ensure your rpm speed is in the pre set area. generators will do this under load when you have a big load on them or take a load off. the governor will some times over compensate causing it to trip on overspeed.
2helpful
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Top OTC Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an OTC Hammering Expert? Answer questions, earn points and help others
