Computers & Internet Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hav to change my os
Rhello sir , i hav installed the windows 7 os ... now i want to remove the entire thing nd would like to install windows xp ... i need xp oly ... pls help as soon as possible
Anonymous
Level 2:
  • Expert 136 Answers
  • Posted on Feb 10, 2010
Anonymous
Expert
Level 2:
Answers
136
Questions
0
Helped
70737
Points
626
Hi sir. its eay to install the xp. First format your pc and then boot it with xp cd if you have the XP cd. else you can download the windows XP from the following link:
http://www.softwarepatch.com/windows/windows-xp-service-pack-3.html
or
http://www.soft32.com/download_123572.html
all the best..
Sir i installed 2 os windows xp(shows earlier installed os) and windows 7 now i want to remove windows xp which had disc error while installing it and it does not start but win 7 works fine?
it can be difficult to remove, your best trying to repair it with the same install disc first, or just forget it's there and you can manually delete the windows folders/files, removing can be tricky with dual boot unless you put it on a seperate drive then you can just format the drive it was on but backup your working OS first just in case, i had same issue and googled for long time and decided to leave it where it was in the end to avoid problems, there is a way to stop it showing up at boot up if your getting the option to boot from 2 OS but i forget how to remove this now, a quick google will show u.
tip
Upgrade Windows XP to Windows 7 - it is possible!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
Dear sir/mam I want to install win xp in a win 7 installed laptop, (compaq 510) but there was some error to install it (blue screen error). Sir please help me to install win xp the same system with...
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
http://www.windowsxpprofessional.windowsreinstall.com/indexinstallguides.htm
Sir i have hp pavilion6 laptop .and used windows 7 os but it has corrrupted now i wish to install windows xp or xp proffesional .and when i put the xp os cd it has not boot from cd wheather xp suitable for...
You need to change the boot order in bios so that the computer starts from CD-rom. Then if it still doesn't start the cd, make it so that it only starts from cd and not the hard drive.
if its still not working theres a problem with the cd try another one.
let me know how you get along with it.
1helpful
Sir i have aspire 4738z p6100 with windows 7.can i use xp operating sys.
Yes you can use windows xp thereshall be no problems.
In order to use windows xp you have 2 options,
1. Install windows XP on your computer ( that will remove windows 7)
2. You can make it a dual boot where you can have both the operating systems. (win 7 amd win xp)
To install windows xp you will need a windows xp os disc with a valid license key with the help of the disc you can install windows xp.
1helpful
5answers
I have installed windows 7 on my acer aspire 4736. The thing is, whenever I lower down or push up the volume on my laptop, no icons for the volume can be seen on the screen. also when i switch on/off my...
I had a similar problem when my driver wasn't installed. Go to the manufactures website and find the soundcard driver for windows 7. If you cant find the soundcard driver designed for windows 7 try downloading the vista one
1helpful
How to download VGA Driver For Windows & version
maybe your driver is not supported with windows 7 os. just stick to windows xp
How can i update the system to service pack 3
there of lot of changes done while installing updates and it especially changes some registry values too... so sometimes it affect some programs which are running well and would become ok once the program is reinstalled but there might be data losses to avoid this only it is asking you to backup... the entire os is not reinstalled...
4helpful
4answers
How to format Satellite A200-24A
Sir,
Iam using toshiba Satellite A200-24A model laptop.already this laptop contain windows vista. i want to instal Windows 7.can you please help me how can i install Windows 7 and how can i download the 7 drivers.
Please Help me
and send me the result
[email protected]
Grand Canyon Tech
Grand Canyon Tech
