I own the SR90VE recorder and am having a problem copying from VCR to DVD. I have done it in the past, but after following proper steps, then pressing Dubbing button, the dubbing VCR - DVD light flashes a few times, then stops, leaving the VCR tape on pause. We are using DVD-RW 4x discs. Please advise. This is very frustrating...
I have the exact same problem! I emailed Symphoic today on the problem!I own the SR90VE recorder and am having a problem copying from VCR to DVD. I have done it in the past, but after following proper steps, then pressing Dubbing button, the dubbing VCR - DVD light flashes a few times, then stops, leaving the VCR tape on pause. We are using DVD-RW 4x discs.
You can't post conmments that contain an email address.
I have 3 of these machines. I do not think it likes theRW disc's. Two of my machines are 4X & one is 8X. I have very great success with 4X DVD-R & 8X DVD-R disc's. I hear they have a fix for upgrading to 8X speed. Here is the link with the information:
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
Can you provide the model of DVD/VCR player? Not all models do this.
For the ones that can, you need to use the Dub feature. Put a blank DVD (or one with sufficient space) in the DVD tray; initialize the disc if you are using a rewritable disc (RW). Then put the VHS tape into the VCR (you may want to break off the write protection tab). Then set the unit to VCR mode and forwared the tape to the desired recording point (copy-protected tapes can't be copied). Then some models have a dub or copy button on the unit and/or on the remote (press it and follow the onscreen prompts to select VCR to DVD, recording quality and press Enter to start). The copying will stop when you press Stop or run out of space on the DVD. On some models, you need to do this with the on-screen menus. For those, the look for a Dub feature (where it is will vary in the menus - usually in the same submenu as timed recording) and then select VCR to DVD and the rest.
I hope this helps.
Cindy Wells (I'll be glad to provide more information if you provide a specific model. I've worked with several brands and there are some differences in the setup routine. My current unit is a Zenith with a Copy button on both the front panel and the remote.)
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
Cindy Wells (only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable. 1
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [K / L], select “Advanced Setting Menu”.
Hit [ENTER].Advanced Setting Menu will appear.
Using [K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [K / L], select “Dubbing Mode”. Hit
[ENTER]. Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication: • After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction. 5
Using [K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit. Make sure to select a recording speed using [REC SPEED]. 7
Hit [PLAY B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP C] to stop the recording. When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically. • Dubbing Mode is available only if the videotape or disc is not copy protected. • You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
1. Insert a blank DVD disc in the DVD deck and close the disc tray. 2. Insert the VHS video tape you wish to copy into the VCR deck. 3. Find the place on the VHS tape from which you want to start dubbing using the PLAY, FF, REW and PAUSE functions. For best results, pause playback at the point from which you want to record. 4. Press the DUBBING button on the Remote Control or DUB on the front panel. The Dubbing menu appears. 5. Use the arrow keys to select the desired Record Mode: EP, LP, SP or XP. 6. Select [Dubbing] then press ENTER or DUBBING to start copying. 7. To stop dubbing at any other time, press STOP (x). Dubbing will stop automatically when the VHS tape ends.
