Does anyone know the universal remote code for the Magnavox MWD7006 DVD player? I bought a universal GE remote and I can't seem to find the code for the MWD7006. Any help would be greatly appreciated. Thanks!!
4 digit code is 0458
447 worked for me. The player is actually a Funai and that's what the code is listed under. Hope that helps! :-)
None of those codes worked for me either, but 0675 did work.
WOW!!! Thank You SOOOOO much. (* * * * *) I was about to give up, when I saw this page. I got a Manavox DVD player from the pawn shop and I have a Universal remote. None of the codes worked and none the codes I found on line worked either. This the one that did 0258!
Do any of the universal codes enable access to the DVD player's menu system? I've got a couple universals since losing the original, but want to get into the menu system to change the aspect ratio after getting a new TV, but the codes only seem to enable the usual DVD menu options and play control, but I can't get into the console's setup.
For a Vizio Vur 10 remote, to program a Magnavox MWD 7006 DVD player use code 361.
I'm looking for the code using a aa59-00356 on the same device. would it differ depending on the remote using the code?
Has anyone found the code to the GE universal remote
same
I too am unable to find the universal remote access code for the magnavox mwd7006...I've tried 0258, 447, and 0458 mentioned with no result...I'm contemplating placing the unit on my driveway and driving over it with my truck a few times...the more I think about it the more I believe this may be the best solution.
