An internal wireless card lets you access the Internet and a home or corporate computer network without the hassle of using an Ethernet or other type of network connection.
The wireless card grabs the communication signal flowing throughout the air and processes the signal through your Gateway PC's Windows operating system so you can access websites, email and related Internet-based services.
But like other devices in your computer, you must turn on the internal wireless card in your Gateway PC before using it.
Turn on your computer, if it is off.
Press and hold the "Fn" key on your computer's keyboard.
Press the "F2" key in the upper row of keys on your keyboard.
The wireless Internet card's connection utility will start searching for a wireless signal.
Connecting to a Signal
Click "Start," "Connect To."
If your Gateway PC is running Windows 7, click on the Windows symbol on the taskbar. Click "Control Panel," "Network and Internet," "View network status and tasks."
Click on the wireless connection you want to connect to.
If using Windows 7, click on "Connect to a network," then click on the wireless connection you want to connect to.
Click "Connect." Enter the wireless connection's network password (SSID), if prompted. Click "Next."
Click "Connect Anyway," if prompted with a message about the connection not being secure.
Click "Close." Open your Gateway PC's Internet browser or email application to start using the Internet connection.
Networking Your Computer
http://support.gateway.com/s/manuals/mobile/8508773/8508773m.htm
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark!?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamationmark! or a red Xright click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
http://download.cnet.com/Gateway-Wireless-802-11g-PC-Card-Adapter/3000-2112_4-73884.html
http://download.cnet.com/Gateway-Wireless-802-11b-PC-Card-Adapter/3000-2112_4-68468.html
You only need to check BIOS if you are " unable to install the driver "
Make sure you Ethernet/internet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigateto integrated peripheralslook for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
