Dell DJ Ditty MP3 Player Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display backlite works, but there is nothing on the screen. when i try to troubleshoot it on my computer it tells me there are no drivers installed should there be drivers and where can i get it
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 19, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470255
Points
19564
3answers
Lenovo g550 laptop with an external monitor only displays on broken original screen after crash dump
Download and install the display driver from the link below:
http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g550-notebook
Won't display 1920x1080
I think you could have loaded the driver for a different model with 16:10 aspect ratio. Uninstall that driver.
Can you connect using the DVI port - get a DVI cable if your computer has a DVI port. If your computer has HDMI get a HDMI-DVI cable. DVI port will display max resolution - even without driver.
Why can't I change my screen resulation on my CM2017 monitor I have tried changing the setting from the display setting program and the resulation wouldn't move. I have also gone to a lot of different web...
The most likely reason why you cannot change the screen resolution and a higher bit color is the incorrect video driver was installed on the computer.
Go into Control Panel - Display, click on Settings - Advance - Adapter. If the adapter is Generic VGA driver then you need to install the correct.
You need to identify the video card and install the correct Windows version of the video card driver.
1helpful
Studio 15 screen blank
there is an inbuilt hardware diagnostic..
turn the computer off then hold Fn + power button to turn it back on.. it will automatically initiate PSA diagnostics.. will beep and ask you if u see the colour bar displayed.. if u see them respond accordingly or else.. let it run.. within 10 minutes you'll get an error if its hardware glitch.. call dell tech support at 1800-624-9896 and tell the error code.. they will replace the lcd kit by sending a tech at your place.
Display problem
see frnd it generally occurs when graphics display driver is not installed in urs computer.....
can u tell me ur computer configration..
then i tell u wat display driver u need to installl...
ask me at live support if ur havin more problems.....
1helpful
2answers
Screen goes black and no backlite when connected
Please reduce the resolution/ Frequency of your Display Card in system and see whether you can see some thing. Else connect this monitor to another system with low resolution. Let me know your feedback.
2helpful
Can't change monitor display settings
no drivers are needed for monitor. Its the video card drivers that you should look for at the dell drivers and downloads website. make sure that you have the right driver installed so that you may be increase your screen resolution.You may also use your Dell Resource CD Drivers and utilities. Install the Resource cd, On the TOPICS dropdown box, select drivers,You'll know which drivers needs to be installed because they will have a check mark infront of the correct device driver. Clicke extract button after you have chosen the video driver. You may need to scroll down.Restart the computer.
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
