Winter Sports Logo
Anonymous Posted on Feb 10, 2010
MY 1995 POLARIS INDY XLT WAS RUNNING FINE THEN I GOT IT HOME AND NOW 1 WEEK LATER IT WON'T START. I CHECKED THE PLUGS AND THEY WERE FIRING. I REPLACED THEM ANYWAY, AND STILL THE SAME. WON'T TURN OVER. IT HAS A PULL START. I ALSO SPRAYED A LITTLE STARTING FLUID AND STILL NO LUCK. ANY SUGGESTIONS?
xxxx
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 08, 2019
xxxx
Contributor
Level 1:
Answers
Questions
0
Helped
721
Points
I have the same machine and my experience is never touch the gas when trying to start it choke only if it is warm no choke
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2107
Points
6
Your carbs are out of tune
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Polaris_xlt coils and there wiring positions and were they all go
I will check ,im waiting on an xlt to arrive for repair this week or next.
2answers
I have a 1995 Polaris Indy 500. The engine floods out immediately. Once so bad yet a friend was going to borrow my machine it was running out of the exhaust pipe. If the plugs are dry, you get one pop...
SOUNDS LIKE WOUR NEEDLES ARE STUCH OPEN. A CARB REBUILD IT GOING TO BE NEEDED. TO GET IT UN FLOODED, REMOVE THE SPARK PLUGS AND TURN THE GAS OFF. THAN START PULLING IT OVER. U CAN ALSO LET IT SIT WITH THE PLUGS OUT FOR A DAY OR TWO AND LET THE GAS EVEPORATE, MAKE SURE THE FUEL IS SHUT OFF THOUGH
93 polaris xlt tripple wont run to full potential
The issue I had with my 94 was due to an oil adjustment, wich you can find below the carbs. It ran great at full throttle but once it sat at idle, the plugs would get wet and the same type of bog would accure. Get new plungs and make sure all three are firing first, if they are then the oil adjustment is off. If not sorry to say but you may have a bad coil.
Indy 500 motor knocks
could be bad gas. try running fresh gas. if that dont work you have internal problems. make sure it is firing on both cylinders though. when you start it cold you can feel if one is running hotter than the other. do a compression test. 120 psi is normal and no more than 10 lbs difference between cylinders. if one is low motor needs a rebuild
Top Polaris Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
