Televison & Video Logo
Posted on Feb 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote does not work
We bought the floor model from Best Buy. It didn't have a user's manual. The TV set is not connected to cable, it was bought for it's included DVD player. Since the beginning, the remote did not work with the DVD. Best Buy replaced the remote with a universal one, but this does not work either. It does not start the DVD, forward, pause, etc. the only thing I can adjust with the remote is the volume.
I appreciate any help I can get.
  • magdaf Feb 25, 2008
    The TV/DVD combo is a Toshiba, model 27HLV95 and the universal remote is a Philips Universal with no model number on it.
    he TV/DVD combo is a Toshiba, model 27HLV95 and the universal remote is a Philips Universal CL032.
Anonymous
Level 3:
Genius:
  • Master 3,422 Answers
  • Posted on Feb 23, 2008
Anonymous
Master
Level 3:
Genius:
Answers
3422
Questions
Helped
1025541
Points
9479
Can you please tell me what is the model no. of the universal remote also the Brand and the model no.your TV so that i can help you fix the problem.
Waiting for your reply..
  • Anonymous Feb 23, 2008
    Here are few codes i am sure they will solve your problem:
    0159, 0178, 0109, 0120
    0181, 0105 ,0049 ,0095
    0170 ,0260, 0358, 0394
    0924, 0012, 0095, 0117, 0141
    Please let me know what is the model no. of the remote so that i can provide you with more codes if the above one's don't work..
    Goodluck,
    Please don't forget to rate me as fixya if your problem is solved..
  • Anonymous Feb 25, 2008
    Hi again,
    Did you try the codes which i gave you?Here are few more.
    0517,0419, 0512, 0613
    0719, 0112, 0506, 0111
    0618 ,0627, 0437, 0041
    0094, 0802, 0111, 0313, 0715
    If these don't work then please do the following steps:
    Programming a Device using Code Search:
        Manually turn ON your device (TV, VCR, Cable Box)
        Press and "HOLD" CODE SEARCH
        Press and release the device button you want to
        set up (TV, VCR, Cable Box) However, if you are using AUX for a device,
        press and release AUX first and then the device button for the type of
        device to be programmed (TV, VCR, or Cable). The selected device button
        will flash once.
        Release CODE SEARCH.
        Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
        Once the device turns off, press and release ENTER.
        With the device on, press any other button. If
        the device responds, no further programming is required. If the device
        does not respond, repeat steps 1-6.
    Goodluck,'
    Please don't forget to rate me if your problem is solved.
Damen Wong
Level 3:
President:
  • Master 1,950 Answers
Damen Wong
Master
Level 3:
President:
Answers
1950
Questions
0
Helped
1027687
Points
5739
What is the model of your universal remote?
  • Damen Wong
    Damen Wong Feb 23, 2008
    It needs to be programmed to work with your TV.
  • Damen Wong
    Damen Wong Feb 25, 2008
    Thank you.
    Did the codes above work for you?
Changing TV, model CKT2521. Classic number CH- 10C. Where can I get a replacement remote control?
You should verify in the user's manual of the remote you mean to buy if your TV brand is listed. Bad new is thart models are not listed.
Your TV may appear with several codes
You should feed the code according to the instructions and test the remote.
It is possible that none of thse codes will work; then your only rsourse might be to scan your remote according to provided procedure, until you get some response from the TV.
In worst case, if no code works, you should return the remote to the shop where you bought it and find another one, so maybe buying that remote from some online webstore might not be the best solution
Bought 40" TV was floor
Try going to Remotes.com they have original remotes for all major brands.
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
2answers
Need a remote or tv code
Most universal remotes will work and the code will always come with the remote. There is not one set of universal codes that come with the TV. The codes are remote specific, so if you are looking for a code refer to your remote instructions and manufacturer and not your TV literature. Your best bet to get full functionality is to get a logitec harmony remote. They usually cost a bit more and take more to program but they are the best I have found to absolutely get all the function you could ever get because you can program as many extra buttons as you want. Another option is to call the manufacturer, their number will be listed in the user manual. They can send you the original remote. It may cost somewhere in the range of $15-$50.
Voire lcd20v31 tv dvd combo
Wow - unbelievable - they should be sued. I just bought a floor model that had been returned. The returnee did not return the remote or the manual, so it appeared to be a great buy. Now i believe they bought it purposely for the purpose of taking out the remote and manual and then returning the pc for a refund. Got on here and saw your post, because we too could not find a remote that would work on this tv/vcr combo. - RIDICULOUS!!!
Programming tv into cable remote
Do you have the cable remote book? The book will be able to tell you what code you need and how to program the cable remote. If you don't have the book for the cable remote call your cable company for it or look for their vans driving around they usual have the book for the remote.
3answers
Samsung HD tv
Your TV should be an output, only the cables are different.
Let me know the exact model of your tv, and what cable you are using to connect it, so that I can give you more information.
1helpful
3answers
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
