Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
Anonymous Posted on Feb 09, 2010
Even after changing the battery, the display fades on a Timex.
Even after changing the CR 2016 battery, the display fades almost immediately on my Timex Ironman Triathlon. I reset the new battery and the display worked for about ten minutes, faded, then disappeared entirely. It happened twice and those batteries are expensive!
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Feb 11, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290949
Points
7081
It sounds like a short circuit somewhere in the watch. A visit to the authorised dealer sound necessary.
To find your nearest dealer go to "casio.com" click on "support" , then from the menu on the left, click on "repair and service" to find your dealer or service center.
Testimonial: "Thanks for the feedback. It's out of warranty and I'm not sure it's worth it. "
  • Deanna Hoppel
    Deanna Hoppel Oct 02, 2013
    i have replaced the battery but I can't change the time . none of the buttons works.The back of the batt. holder suggest doing something after changing the barrery!
Instructions for Timex CR 2016 748 L8 (Wanted)
Hi m_cox840,
If you don't have the manual, this is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
My timex cr 2016 cell timex watch beeps every hour..how do I stop this
Hi When you set time you have to make the alarm indecator disappear to stop. Good luck.
1helpful
I have a Timex Ironman 30-Lap Mid watch with a dead battery. I purchased a CR 2016 battery as stated on the back cover of the watch. How do I change the battery?
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
I have a Timex I bought in 2007 on the back of the watch it says CR 2016 cell and WR 100m. The time started to catch on a certain time and stopped the date from working properly, I need to know how to...
You should probably replace the battery using a new CR2016 battery. Let the watch set a while without the battery to help it reset. WR 100m just means the watch is "Water Resistant to 100 Meters". Then use the following info.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 • Watches
Timex CR 2016 Cell N8 - been to local repair, not a battery problem and so solution to failure to run. To whom can i send this for timex parts and repair?
Go t Timex.com and click on "product instructions guides and downloads".
You will then see a page with a menu on the left. Choose repairs.....
My Timex men's watch ran fine for a couple of months and then started loosing several hours over a 48 hour period. I changed the battery but after a while it began to do the same thing. The id on it is:...
If it is only two months old and you have proof of purchase (did you register the warranty?), the take it back.
Most watches have at least one years warranty.
Mar 08, 2010 • Watches
Timex watch battery
depends on where you buy them and the brand they can range from 1 dollar on sites such as ebay or 2.99 at stores such as walgreens or cvs (drugstores) or walmart, battery plus etc.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
