If the drive is external, you can try to remove it from its case and attempt to read in using another adapter. If the drive itself will not spin up a data recovery service may be your only option (usually expensive)
Which type or external drive you have (PATA) or (SATA), connect your driver to your External drive case, The external drive case have both of connector to connect the drive, chose your drive and connect the drive and connect the power, that ok
Now close your drive case and USB one side put in external drive case and second side put your Com/Lapi and switch on your external drive, your com/lapi detecting your external drive and your see the my computer external drive now what ever data you want to store, copy and enjoy
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
Disassemble the case, and remove the disk-drive.
Attach it as a "slave" disk-drive in some desktop computer, and see if the desktop computer can "detect" the disk-drive, and if the files on the disk-drive are still accessible.
Try taking it out of the casing and putting it into another external hard drive case. That is if you can, if its making a clicking noise it probably means your hard drive went bad or it means its not getting enough power to run make sure all the cords are hooked up tight. I had that problem once the hard drive wasn't getting enough power and i had to mess with it on the inside to make it have enough power. I'm not saying take the hard drive apart im saying take the casing off it and check the inside cords to see if they are tight enough. If that doesn't work leave a message and ill try to help again.
The hard drive could be damaged but the USB adapter case electronics is OK. Therefore the computer can see the USB device (adapter case) but not the hard drive. If the hard drive makes a clicking noise or you cannot hear the hard drive spin, then the hard drive is definitely faulty.
There is very little chance you can recover data from a faulty hard drive.
There are companies that can recover data from faulty hard drives but it will cost you an arm and a leg for their services.
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
The extra 4 volts of electricity may have fried the electronic parts inside the external drive's case. In other words, your hard drive may be ok even though the little circuit board that matches the external hard drive to your pc's USB outlet is ruined. A computer shop can remove the hard drive from the external case and test that drive to see if it's still working. That's the best case senario. My best guess is that you cooked the electronics in the external case AND the hard drive. So sorry.
ok so there are a few things you can try. firstly simply remove the case and see if anything internal is damaged, DO NOT go and start prodding a pulling anything that seems broken, as odds are you will make it work. If there are any internal damage odds are you wont be able to restore any data unless you get it fixed by a professional. My solution is to take the Hard drive from its housing and put it into your computers dvd drive, inserting all necessary cables eg power supply and the reader cable. dont do this when pc or hard drive are switched on. this has happened to me before and i was able to recover all of my data. hope this helped. josco91 =)
i have a feeling its not the hard drive thats bad i think it sounds like the case . you can try buying another case and transfering the hard drive to it the case is around $20.00
