Question about Goldstar DH5010B Dehumidifier
Goldstar Dh5010, evaporator is freezing up on one side
  • Goldstar Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Apr 30, 2010
SOURCE:
GOLDSTAR DEHUMIDIFIER SUDDENLY NOT LEAVING ME MUCH WATER IN CATCH...FREEZING UP IN BACK?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 19, 2011 | LG DH30 GoldStar Dehumidifier
GoldStar dehumidifier coil freezes up within 12 hrs of operation. I have cleaned the filter
heatman101
Sep 28, 2010 | Goldstar DH304 Dehumidifier
The coils freeze up after less than a half hour of running. It does not matter what humidity setting I use or if I select the 2 hour or 4 hour run cycle. B/c the coils are freezing up, the dehumidifier...
the coils freeze up for one of two reasons .. if air flow is blocked .. sometimes by dust buildup or fan bearings needing lube .. second if the fan is working properly then ice buildup can be caused by low refrigerant levels .. the proper charge produces a steady coolness across the entire evaporator (cold coil) .. as the level drops it tends to cool a small part of the evaporator way too cold .. that creates ice .. the ice blocks the air flow and soon the whole thing is blocked ...so check the fan first .. if its running properly and there is nothing blocking air flow then suspect low refrigerant.. that requires adding a saddle valve service port to the system to allow adding refrigerant .. often the problem is caused by the fan not working at all because of lack of lube in the bearings or a bad starting capacitor ..
Aug 15, 2010 | Goldstar DH504EL Dehumidifier
Dehumidifier freezes up
heatman101
May 26, 2010 | Goldstar DH5010B Dehumidifier
Coils are icing up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 03, 2010 | Goldstar DH504EL Dehumidifier
Goldstar ghd30
Make sure condenser is clean.
Apr 10, 2010 | Goldstar DH304 Dehumidifier
Same with me
heatman101
Aug 31, 2009 | Goldstar DH5010B Dehumidifier
Goldstar Dehumidifier compressor short cycling...
If the coil is freezing up and the compressor is short cycling,there must be a low pressure switch opening, do to either, low on charge or not enough air across the coil.
Jul 05, 2009 | Dehumidifiers
Dehumidifier freezing up, is it the de-icer control? can it be replaced ?
Could be the tempurature of the room you have it in. Make sure it is not operating in a room below 65 degrees F or 18 C
Sgt 48
May 09, 2008 | LG DH30 GoldStar Dehumidifier
Goldstar DH5010B Dehumidifier Logo
201 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
