Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brushes donot turn when asked to shampoo - Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
usavacuum
Level 2:
Scholar:
  • Expert 57 Answers
  • Posted on Feb 28, 2010
usavacuum
Expert
Level 2:
Scholar:
Answers
57
Questions
Helped
29494
Points
103
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
How do u remove the bag to make it a shampoo
You can unclip the bag at the top where it attaches just below the handle. The base of the bag actually turns and screw off. Turn the bag outward and lift off. Then fill the shampoo attachment and screw it on just as the bag screwed off. But make sure you attach the shampoo brush and attachment. Can't use the regular power head. The video is pretty helpful if you still have it. If not, try Utube
1helpful
I am having a problem getting one of my brushes off. The other 2 came off very easily. Is there a trick to romoving them? Also, do I use the knaplifters before or after shampooing?
This is the Floor Pro for those wondering.
Generally, giving the brushes a quick tug with a counter-clockwise twist will get them right off.
The naplifters can be used either way, but generally are used after shampooing. Be aware that if you happen to have Berber or any looped carpet, absolutely don't use the naplifters. (I hate Berber!)
For best results, use naplifters, vacuum slowly, shampoo (1 cap of shampoo per line of water), use naplifters, allow a couple hours to dry, vacuum slowly. Vacuuming slowly removes the maximum amount of dirt from the carpet and even under pad.
1helpful
I have a kirby sentria vaccum carpet shampoo system and I cannot get the shampoo suction head to work! It comes on but the belt is not turning. I have tried taking it off and looking at the assembly but no...
I had the same problem at first but figured it out. Make sure before you put it on the vacuum itself, that the shampooing unit is completely together. The belt needs to be taunt like it would be when the brush is turning. Once you put it on and turn the dial to the green arrow, it should be on the vacuum cleaner and will turn the brushes . That was my problem is I didn't have it completely together right. Hope this helps.
Sep 19, 2009 • Vacuums
1helpful
Does my kirby come apart to where i can shampoo furniture . can i use kirby on berber carpet. i have the G series
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
9helpful
2answers
Vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Water spray
Are the brushes turning while you are shampooing? If not then this could be the problem. The turbine is what turns the brushes, it may have gone bad.
Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
36helpful
2answers
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
