im sorry but i dont think you can fix this, mine packed up aswell just as im at lugia in pokemon silver :( but mine froze i didnt see this game pak thing im sorry, you'll have to start a new game, i know how it feels :(
You may try this ipod transfer, it's a nice iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes. It can also help you manage multiple iPods on one computer or manage iPod on multiple computers, even copy music and video from iPod back to computer or iTunes. So you will not lose your iPod files even though you switch to a new iTunes library. My friends recommend it to me, it works pretty well. http://www.ipod-transfer-copy.com/ipod-transfer-mediawidget.html Hope it helps. Contact me if you have any other question.
some of the files you deleted are probably the files that contain the installation settings, if thats the case you'll have to restore back to factory settings or download new settings online.
I pod which you is Apple's I think . its only that you are not plugged it proper or you need to install the software of I pod. this is because your computer did not support. please install your I pod software. ok
Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
i took my ipod to the apple store, they ran diagnostics, and it passed everything. i thaught it was a spot on the hard drive, becsue in the process in syncing it stopped at the same number each time (i.e 81 of 334) and freeze. i recently downloaded a song from a website, when i put it on my ipod when it still worked, it would freexze my ipod each time i tried to play it. it was just that one song. then i synced again, things were fine with it for a whle until i sunced it a month later. Apple told me there was a bad song pon there and i instanty knew it was that one and i deleted it. ever since, my ipod is fine.
to find the bad songs, Apple told me to make playlists of my library, in like quarters, sync one at a time if for example the 3rd playlist has problems going on, the song is on there. and just narrow it down. i deleted each song that froze in syncing like 81 of 334.. i would delete #81. (it gives the title you know that) i ended up just having to delete 1 podcast episode and one song, and things are fine.
if you have this problem, plug your ipod up to itunes, on itunes go under the menu , under help> diagnostics. (second to last one) and run it on connection, or anyting you want.. to make sure it isn't on the connection. if not, you have a bad song. also KEEP YOUR SOFTWARE UP TO DATE!!@
My ipod nano won't play music just through my headphones- it also plays through speaker and it makes the music sound like you are in a tunnel. How do I turn off the external speaker?
to "manually update ipod" if it is set to autosync then all tunes in the library which are registered as being on the pod will automatically update. each time you connect the pod the itunes sw will update the pod from the library.
when the pod is connected and auto sync is active if you delete a tune from the lib it will update the pod and delete the same tune.
can you put a photo on how it looks like right now?.. try google images to search for the right photo.
is it like this?
