The display on the screen of my KX-T7730 shows the extension no. (101). I would like to restore the previous display I had (which was the current date and time).
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook : 1. Press PROGRAM * # followed by the system password ( default is 1234). 2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). 3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. 4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. 5. Press PROGRAM to exit program mode and you are done.
If you have a KX-T7730 phone press the * button until it shows your extension number. If not, phone the switchboard operator (usually 10, 101 or 9) and ask the person what the number on the display is. If this was helpfull please vote Thanke you
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this Press program then 0 Enter (example for Tues. Nov. 11,2008 3:00 pm) would be 081104 2 0300 1 then press store then program again and it's set.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done. PLEASE rate / vote this answer if it was helpful. Thank you.
Basically, there are 2 ways of programming the date and time - the short way and the long way. If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system:
SHORT WAY: From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM 0 2. Enter Date and Time ( The format is: yymmdd, 1 to 7 1=Monday 2=Tuesday etc, hh:mm, 0 or 1 0=AM 1=PM ) see example 3. Press AUTO DIAL / STORE to save your changes 4. Press PROGRAM to exit program mode
EXAMPLE: If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows: 100203 2 02:15 1
LONG WAY: From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM * # followed by the system password ( default is 1234). 2. Now press 000 and then SP-PHONE. Enter the year. 3. Scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. 4. Now scroll right again and change the date and day. To change the day, again use AUTO ANS / MUTE 5. Scroll right again and the time will appear. Set the time. To change am/pm scroll to it, and again, use the AUTO ANS / MUTE button. 6. Press PROGRAM to exit program mode and you are done.
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done. PLEASE rate / vote this answer if it was helpful. Thank you.
The side buttons is programmed as extensions To change the extension names follow these steps :
open the system programming(its the phone connected to jack 01) press
program button and enter * and # followed by the password(1234), then
enter 104, press 'SP-PHONE' then auto/ans button to select, select external music,
press store button.
SORRY I FORGOT THE SP-PHONE BUTTON, Dont worry about the display "101" just press # it will change to date and time.
