Once you get the top off, there are 2 thermostats on the top of the boiler. Your looking for the thermostat that is on the front of the boiler with the red button . Push the red button. If that didn't work check the ohms reading on the element. It should read 12 - 16 ohms. If it doesn't replace the element. Also did you try to turn on the steam button? Sometimes the thermostat with the red dot on it goes bad. If it will steam just replace the brew thermostat.
