My son has a Dell Inspiron 910 and when trying to start the laptop, we keep getting this error message PXE-E61 Media test failure, check cable PXE-M0F exiting PXE ROM. Operating system not found. What can we do??
There are two things that could be a problem. The BIOS settings are corrupted, or the hard drive system has a problem. In order to fix the BIOS problem, at boot up you'd hit F2 (or whatever key is required to enter setup). Get some paper and pencil and go through the BIOS pages and mark down anything that is not a default setting. Find the location to reset the BIOS to default settings and perform this action. This will overwrite your BIOS settings and remove any corrupted data. Now, when you reboot, go back into the setup and set all of the settings to the choices you marked down before.
If this does not fix your problem, your hard drive control system has a problem. It could be as simple as a ribbon cable being loose or as bad as the controller section on the motherboard has gone out. Another possibility is the hard drive has given up and needs to be replaced.
