Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
Generator cuts out - fuel filter changed, new oil and gasoline. All basics done. Starting cutting out after 2 hours, then 1 hour and now only cuts out at 5 minutes- Housing clean, no corosion
    New Friend:
I have a northstar generator with a 13hp motor,gas is now mixing with the oil,is this an expensive fix? (it's 8000 watts)
Posted on Oct 28, 2012
    Problem Solver:
  • 12 Answers
Sounds like the carb should be pulled off and cleaned.Make sure to clean the jets and needle valve
Posted on Feb 09, 2010
SOURCE:
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
Fuel cut out
Did you check the oil? A low oil sensor will disable ignition if more than a quart low.
May 23, 2017 | Acura Integra Cars & Trucks
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
I have a 2006 sportage kia, I have had the timing belt changed, a tune up done, the transmission fluid flushed, my car has approximately 82, 000 miles on it. I service it ever 3, 000 miles. However, when i...
could be a lead or plug breaking down which are the most obvious when under load ,but please explain why the transmission oil changed ?? i was always taught that auto boxes are for old women and the oil in them never needs changing .I have never seen this on any workshop manuals for the need to change the gearbox oil on a auto.
Sep 06, 2010 | Kia Sportage Cars & Trucks
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
Mar 24, 2009 | Watts Onan Portable Generator - 4000 ,...
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Sep 20, 2008 | Electrical Supplies
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
336 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Sheldon Dedek
mikenearman
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
