ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install VGA of Video card - ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
Anonymous
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Feb 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
17664
Points
267
With your VGA card in pci slot locate the vga pci slot in our motherboard insert it firmly. Turn on the pc and make it sure that pc detects your new card and install the vga card driver supported by the manufacturer.
1 Related Answer
Anonymous
  • 1226 Answers
  • Posted on May 12, 2008
SOURCE: Help me please Video Controller (VGA Compatible) is not wrong
download the driver that match in your operating system and then install it to your system.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N8-VMX
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
I dont have vga memory gta saying you have enough video memory i want to download vga memory
VGA memory is the amount of physical memory on the video card. You would have to purchase and install a new card.
Always look at game requirements when buying and installing games. gl
Graphic card location inside an E520
The Dell 520's manual can be downloaded here. The PC's motherboard optionally has a VGA Video Connector (integrated) as shown on Page 1 of the manual. If yours is equipped with this option, there is no graphics card installed - it is built into the motherboard itself. It can not be removed or separated from the PC.
Your PC may have a a separate video card installed into one of the expansion slots on the motherboard. Page 1 also shows this installed below the USB 2.0 connectors as the PCI Express graphics card.
Here's an internal view:
The video card in the picture is driving two standard analog VGA monitors (blue cable connectors) through a DVI -> VGA adapter (white and clear devices) this is connected to the video output connectors. If you look closely at the edge of the PC in the picture (directly above the USB & network cables) you should be able to see an unused VGA Video Connector (integrated). Most computer BIOS systems will automatically disable any built in video capabilities of the motherboard when a separate video card is detected. Check the manual for additional info about these BIOS settings.
I hope this helps & good luck!
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
2answers
I unable to play a game because VGA compatible device not found in my computer & i want to install this. How can i install this explain it? & i am using XP
VGA compatible device not found represents that either your bios couldnt recognize the VGA hardware or your OS pnp service couldnt initialize the Hardware for VGA. Either these cases, we should look for the level of Hardware detection at which it fails. If its an onboard VGA device, you may need to replace it with an addon VGA card based on the Mother Board compatibility and then try install it again. This should solve the issue.
Good Luck.
Would like to find a bios manual to turn off the on board video so i can install a new video card
hi there,
NO need to turn off your on board video (VGA on Board), just plug your Video card in, plug your vga cable to it then install the driver.
dm
Black Screen after installing new NVidia 9400GT
Put the old card back in, remove the old drivers and restart it in VGA mode.
You don't say what operating system you use, but XP & Vista you should be able to hit F8 before the windows splash screen to select VGA mode or Safe Mode.
Once you do that you should be able to put the new card in and start it in standard VGA mode then load the new drivers.
2helpful
No video output from atapi dvd rw after OS reinstall, cd rw ok
>> VGA controller (vga compatible) error in the device manager
Windows has not found a "good" device-driver for the "integrated" video-controller on your motherboard; it is using the "generic" adapter.
So, trying to download the "SIS Mirage Graphics" software is an attempt by Windows to download a "specific" device-driver that matches your video-adapter hardware.
You might try installing an add-in video-card, to see if Windows will install the correct device-driver, and still boot-up correctly.
Otherwise, take the computer to a qualified technician, for trouble-shooting about your boot-up problem.
1helpful
Sir, i cannot install my video card, what must i do?
It should be install the proper version of your VGA, if not at all, reinstall your operating system to see if this problem exist.
Or try to install your VGA card to another PC, at least you have idea where its your VGA have a problem...
My aspire5600 screen is flickering, is my video card damage?
check first the vga connection maybe this loss only. ..and the driver if installed properly check thevga cable..
the last is vga chep.. vga card... use another vga card if pc..
thanks
3answers
Monitor not getting info from computer
Does the computer beep when it starts? Does the monitor work on another pc? Possible culprits with these symptoms are the power supply and video card.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
