Health & Beauty Logo
Posted on Feb 09, 2010
I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
I NEED TO KNOW HOW TO CHANGE THE DATE AND TIME FOR MY BLOOD PRESSURE MACHINE ITS A AUTOMATIC CVS PHARMACY.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28540
Points
44
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
  • Anonymous Oct 30, 2011
    Thank you so much. Really worked! ~0;-D
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
33918
Points
  • goodolrodg Aug 12, 2011
    Great! I could find no direct CVS or Google reference to the manual. YOU ARE THE MANN!
Anonymous
Level 1:
New Friend:
  • Posted on Feb 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28540
Points
Hold down the L button and it will blink on the time -- hour first -- hit the M button as if you were setting a digital watch and it will advance; hit the L button again and it will go to minutes, THEN month (same procedure) then day of the month. Mine is set for the wrong year but I couldn't figure that one out (it's set for 2014); but keeping track by year should be helpful
  • Anonymous Feb 20, 2011
    PS Before you do any of this, hold down the L and M buttons simultaneously for a few seconds. This will "clear" your machine and put it in "set date" mode. Then follow the steps above to actually set the date and time!!
FierceL
Level 1:
New Friend:
  • Posted on Dec 05, 2013
FierceL
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
40565
Points
Call CVS 1-866-464-6184 and they will email you a copy of the manual.
Anonymous
Level 1:
  • Posted on Mar 01, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
28540
Points
Machine goes up to about 60 then finally shows error 3.What does that mean?
Lisa Wilburn
Level 1:
  • Posted on Aug 30, 2021
Lisa Wilburn
Contributor
Level 1:
Answers
Questions
0
Helped
28540
Points
Need manual for a CVS upper arm Talking Blood pressure monitor. TYPE:BW59 (688.81) ITEM #: 420527
Anonymous
Level 1:
  • Posted on Dec 03, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
28540
Points
0
Mine shuts down and displays "Er 4". There is no error #4
in the manual. It goes from error #3 to #5? What's going on? What's "Er 4" ???
2answers
Hi, I need the manual for a CVS blood pressure monitor BP3MV1-1E (800230)?
previously answered on FIXYA...
Please click the following link... (telephone for mailed copy)
To call CVS at 1-866-464-6184...
ELSE
just search on the BP3MV1 portion of the
MODEL NUMBER.
Hope this helps
Carnac the Magnificent
Re CVS blood pressure cuff machine Model#BP3MU1-1E 800231, what does err 2 mean??
My manual says that error two is unnatural pressure impulses influence the measurement result reason the arm was moved during the measurement remedy avoid unnecessary movement or talking.
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
How to reset time and date on omron - 742 b/p unit ?
I need instructions for using Lumiscope Blood Pressure monitor Model 1094
16helpful
PUT IN TIME/DATE ON CVS MODEL KD556 SKU 800231 BLOOD PRESSURE MONITOR, THERE R 2 BUTTONS, START & MEMORY : NO SET BUTTON
On your model, hold the "start" and "memory" buttons at the same time. After about 3 seconds the month will start flashing in the window. Push the "memory" button until it gets to the month you want. Then hit the "start" button and the day of the month will flash. Push the "memory" button until the correct day of the month comes up. Push the "start" button again, and the hours will flash. Push the "memory" button until the correct hour comes up. Do the same for minutes, and the next time you push "start" it goes into ready mode.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
