Question about Epson Stylus CX5400 All-In-One InkJet Printer
Scaner Epson CX-5400 error message
Epson CX-5400 scaner is not working, it only sends a message error and I can't find the locking system that the manual gives reference
  • 2 more comments
  • JJSS Mar 21, 2008
    I got the same error message. The problem solved after I unlocked the tab on the top left coner . It works but prints out nothing when I press copy B&W and copy color. How can I solve this problem?
    JS
  • mikerazboy May 11, 2008
    Epson Scanner CX5400, red light on, starts as if it will scan, but stops
    The little screen,
    Scanner Error -- See your documentation or call service if necessary
    I've tried everything–won't photo copy
    Printing from Illustrator or photoshop is no problem.
  • Anonymous May 12, 2008
    error message on Epson CX3200 printer
  • Muzzypat Apr 26, 2009
    Scanner error - did the toggle fix and it didn't fix it. Mac OS 10.5.6 - Pat
    Genius:
  • 1,447 Answers
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Posted on Feb 22, 2008
My Epson CX3200 printer has a printing error message that shut down the printing. Paper is not jammed. Ink is OK.
Any tip? Thanks!
Posted on May 12, 2008
I have a error message. (Printing error)
Paper is not jammed at all. Turnoff did not help either.
Any fix? Thanks for any tip!
I have a message on my cx5400 3 in 1 that says
Scanner could not allocate required memory. Quit other application and try again.
I don't have anything else on the screen when this occurs. It runs through the scanning process and then instead of finishing flips out this message.
Any Ideas. I tried turning of the printer and starting over
I have also restarted my computer. No change
Posted on May 29, 2009
    Problem Solver:
My epson 3 in 1 error light is on. theres no way to get into menu. need help.
Posted on May 11, 2009
SOURCE:
Did not work in epson cx 2800 scaner in windows 7
If you cannot get a scanner driver from Epson then you may be able to use a driver from this WEB site.
VueScan 9 scanner driver - compatible with over 1750 scanners
http://www.hanrick.com/
Nov 27, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Hello, i have printer@scaner epson tx100. but i cant make the scaner work. i tried a lot of times to load the drivers, my printer is working, but scaner dosent! my computer do not recognise it!
lapinskyi,
If you are loadiing them from a disk I have a tip at http://www.fixya.com/support/r7723090-setup_all_in_one_printer_scan_computer which tells how to do that or better yet how to download and install the latest drivers from the internet.
Thanks for using FixYa and for the great rating.
hardrocko
May 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My epson perfection 610 scaner is connected with connected with my computer i want to down load the software/drivers
Hi!
You need to go to www.support.epson.com select your scanner and download the software that will work with your Operating System.
Hope this helps. Keep me posted.
Apr 12, 2011 | Epson Perfection 610 Flatbed Scanner
I lost my epson cx 4300 all in one printer ,scaner,photocopy.drive CD
Please follow this LINK, and download whatever you want, including the driver or other canon softwares.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I need a driver for my printer which is Epson stylus CX 3200, please help me to find right driver. i installed one , scaner is ok , but printer does not work .
Depending on the OS you are running, will determine which driver to download and install. Go to this link and download the correct driver. Uninstall the printer completely prior to installing the driver to make sure you get rid of the incorrect driver from the previous install.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14082&prodoid=24875245&infoType=Downloads&platform=All
Nov 29, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Scaner does not work with Windows 7, are there any
Hi
Yes there is a scanner driver available, this however is a Twain driver and you will need to use the "Import" or "Aquire" function from within word, office scanning utility, Adobe Standard etc for this to work.
Check out this link and use the "TWAIN" driver.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664&prodoid=46253282&infoType=Downloads&platform=Windows
Dec 09, 2009 | Epson Stylus CX6600 All-In-One InkJet...
How do i connect my epson scanner 3490 t0 my epson r220 printer
i am not sure if the two could be readily connect. but, you may connect them on two of the USB port on your PC at the same time.
Oct 07, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Escndv.exe has encountered a problem
the website below offers step by step instructions that will guide you to correct the problem.
http://www.tomshardware.com/forum/18636-3-escndv-encountered-problem-close
Jul 08, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
2,151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
