whenever i connect my zen to computer it doesn.t detect or either charge my player. now my player is completely dead. \whenever i connect my zen to computer it doesn.t detect or either charge my player. now my player is completely dead. \
You can't post conmments that contain an email address.
If it is under warranty, get it replaced. The firmware is corrupted and unless the computer recognises it, you can't restore the firmware. If you can get it to come up to the maintenance menu you may be able to reset the player.
This sounds like it might be a hard drive problem. To put it into Recovery Mode, do this: put a
paperclip in the
Reset hole while holding the power button in the On position. Then
release the
paperclip and continue to hold the power button until it goes to the
Recovery
Mode screen. You should at this point try Format and Scan Disk/Cleanup,
then
Reboot. If it still gets stuck at the same spot, then its going to be a
hardware failure.
Click here to
view my step-by-step troubleshooting guide. Click here to
send in your device for free diagnostic testing.
If that doesn't fix it trythe USB cable Screen Doesn’t come on anymore http://www.anythingbutipod.com/forum/showthread.php?t=18859 If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause." Q. How to reset Zen v + http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
. How to reset Zen v + http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize http://www.anythingbutipod.com/forum/showthread.php?t=10960 If that doesn't fix it trythe USB cable
Zen V is dead "If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause." Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize http://www.anythingbutipod.com/forum/showthread.php?t=10960
