Kitchen Appliances - Others Logo
Posted on Feb 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bread stuck to the pan and it rose to much.
Anonymous
Level 3:
Genius:
  • Master 1,036 Answers
  • Posted on Feb 08, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1036
Questions
6
Helped
412183
Points
3010
Remove the container from the breadmaker and use non-stick fish-slice or palette knife to free the sides from the tin. Then tip upside down and shake to dislodge it.
If this fails, remove the bread as best you can and leave the tin to soak in water overnight.
It is best to clean the bake tin by hand as dishwashers remove the non-stick.
Try using packet mixes with a different packet dried yeast. or use less yeast next time.
2answers
Breadman Ultimate can't remove bread pan
Have you tried giving it a little anti-clockwise twist? :)
Trying to make French bread in my toastmaster bread and butter maker. Bread rose, doesn't bake. Machine is flashing 000
If you pushed the button for "French" bread then you do have a problem. If you pushed the "Dough" buttton then the flashing0:00 just means your dough is ready.
1helpful
I have west bend bread maker (new) After 5 perfect loaves, the metal post that the paddle sits on is stuck. It is stuck tight. What happened and how do I get it to move. I turned the pan upside...
we have the same problem with our kenwwod bread machine we was told by kenwood.
you can either buy a new bread pan and bread kneeder or live with it, as in time and use
the new pan and kneeder would do the same agian. the new pan cost around £17.00,
and the bread kneeder around £6.05 from amazon if you do want new parts type in the serch bar at amazon bread maker parts....but if it's not broke don't fix it...........
Bread pan is stuck I can't get it out
Try adding a recipe of ingredients, and run on 'dough" cycle.
4helpful
Pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
I had the same problem few moments ago until I read someone's answer.
It really worked and it won't brake.
Kneading blade stuck
The little bearing that turns the paddle is frozen. You will need to get a new bread pan. This happened to me after 7 years of use. If under warranty have them replace it. It was about $25.00 for a used bread pan on ebay, so I just bought a new machine at Wally World (Walmart) for $52.00.
Hank
3helpful
The knead paddle on my bread machine is stuck, what can I do to remove it. I have tried putting soapy warm water in the bread pan and leaving it sit for 30 minutes, but it did not work. I recieved this...
just go to youtube and type in "how to remove a stuck bread machine paddle or kneading blade" you will see my video of how to remove a severely stuck bread machine paddle.
Bread sticks to the pan
check the pan and see if it needs to be replaced. if it is scratched and worn the teflon coating isn't working properly
Welbilt bread machine kneading blade stuck
I have the same problem. I have used Liquid Wrench and other products to no avail. *sadness* What a shame that I have a working machine but the pan is a goner.
2helpful
Bread sticks to pan
May be that the coating on the pan is just wearing off. Had the same problem several years ago and it was just that the poor old machine was over used and the simplest solution was to buy a new pan. That machine went though 2 of them before it died its self.
- Neil
Top Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
