Tv wont turn on and the sleep and timer lights flash
This problem may come from a bad capacitor in the standby power supply. The part location is C605
This should be an easy fix.
Cheers, CrazyLee
You could have loose connections in the horizontal section not allowing tv to turn on or the standby or secondary supply lines . Also there may be shorts in the power supply and if so check the horiizontal sections for shorts as well . Good luck
I have the same TV and very close to the same problem. If I manually hit the power button several times, I can usually get it to catch. My problem is I don't know where the heck part location C605 is or what a bad capacitor looks like! Help greatly appreciated!
