Electronics - Others Logo
Posted on Feb 22, 2008
Tape stuck in uvw1800 beta cam sp
Help, I cant get the tape out of the deck. Can someone help me?
  • 1 more comment
  • Anonymous Feb 26, 2008
    small beta tape stuck in uvw-1800. HOW DO I GET IT OUT?!?!??
  • raerae28 Nov 26, 2008
    I have a tape stuck in a betacam sp bvw-75.
    How do I eject the tape?
    Thanks
  • Anonymous Mar 31, 2014
    I keep getting an error 3 on my PVW 2800p beta cam deck. I understand that the error is: The slack or breaking of the tape is detected in recording or playback mode, or either of the lock of the supply or take-up reel is detected, and then tape protection is done. Does that mean I need to take it in for a service or is there something I can do in the office to solve the problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3050
Points
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
  • Anonymous Jun 04, 2013
    2013 and this is still helpful. cheers from germany... and yes we will produce HD too....soon... i guess ;-)
Anonymous
Level 1:
New Friend:
  • Posted on Aug 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3050
Points
I hate SONY, every piece of equipment I've bought from them always lets me down from mini DV tapes in the store, to Beta SP tapes, to UVw1800 decks. I've gone through every process in the menu, and nothing helped get the tape out. The last message was "Turn the power off and remove the cassette compartment while holding the lid of the cassette open." Once again, I HATE SONY WITH A PASSION. I removed the lid, unscrewed the screws. The tape compartment moved around a little, but I'm not yanking the thing out at risk of breaking something causing even worse damage. Fidgeted with it some more and to no avail I could not remove the stupid tape compartment. I finally went back to the menu section, found my way to CASS-COMPARTMENT , selected that and it ejected my tape by ripping apart the tape reel. I don't know whether to take a sledge hammer do this deck, or get ripped off from some **** techincal shop charging more money for what its worth to fix the miserable peace of . . . equipment.
A
Anonymous
One of your reel motors died. Most likely the takeup side. If You can't get the tape out by the menu solution, remove the top panel, unthread the tape by rotating the loading motor which is in the rear right corner towards yourself. If the tape doesn't spool back into the
cassette by now you need to do this by using the menu. If you find the "cassette motor" check you might be able to use that to use the one functioning cassette motor to get the tape reeled in to the cassette. Pay attention to the arm that swings out in the middle in front of the drum. It's the "tension arm" and it tends to hang up after about 10 years when the grease in it hardens. If you see that happen the cure could be manually pulling it back while the tape unthreads. Oiling that joint afterwards could keep
it from happening again.
Rich Dudley,
Betacam Expert ([email protected])
9helpful
Sony UVW 1800 error code 02-403 - tape is out, code won't go away
Error 02-403 is "tape slack in ff/rew". Although you were able to get the tape out, the threading ring may not have returned to the unthread position. With the power disconnected and the top of the deck off, look at the mechanism; on the right side, there is a small gray motor with a black wheel in front of it. By turning this wheel, you will be able to make the threading ring turn; turn it so the ring goes clockwise. When the ring has gone as far as it can, it will be in its unthread position, and the deck will probably work normally.
4helpful
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
1helpful
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
2helpful
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
2helpful
2answers
Receiving and Error Code 5
Error 05 points to a problem with one or both reel motors. Not field-repairable for a non-technician.
2answers
UVW-1800 SONY VTR - s-reel error
Both these error codes indicate a problem with the supply reel motor.
The first code (02-058) indicates that the reel motor is drawing too much current, which could be caused by a bad motor, defective driver circuit, or even a bad tape. The second code (02-803) indicates tape slack, caused by the defective supply reel motor. FIRST thing to check would be a possible bad tape. Try different tapes and see if the problem persists. If it does, it may be time to find a technician.
1helpful
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
5helpful
2answers
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
Top Sony Electronics - Others Experts
Sean Wright
Sean Wright
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
