How do I change region on dvd player - Televison & Video
  • 12,061 Answers
As I'm sure you know, DVDs are coded to a region of the world.
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Resevered for Cruise Ships, Airlines, etc...
REGION 0,9 or REGION ALL -- Discs are uncoded and can be played Worldwide
So here we go..
  1. Power on
  2. Open tray
  3. Push the info on remote once (with supplied remote) You will see numbers.
  4. Press 9 for multi-region. keep trying until you see the number 9 appear in upper left corner
  5. Power off
  6. Power on
Best of luck.
Posted on Feb 08, 2010
SOURCE:
  • 86 Answers
SOURCE: Changing region on a DVD player
You did not specify what kind of DVD player this is? Since you said player, and not drive, then I will assume this is a dvd player you hook up to your TV, not install in a computer.
Simple answer, you can not change the region code on a DVD player, unless there is a known hack listed on a website.
Therefore, your only option, is get a region free dvd player. They are cheap and easy to get on amazon.
here is one for $30:
http://www.amazon.com/Philips-DVP642-DivX-Certified-Progressive-Scan-Player/dp/B000204SWE/ref=pd_sim_e?ie=UTF8&qid=1196024533&sr=8-9
Posted on Nov 25, 2007
jaffa012001
  • 376 Answers
SOURCE: Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Posted on Aug 12, 2008
jaffa012001
  • 376 Answers
SOURCE: changing code for dvd recorder+vcr Sanyo hvr-dx625h
1. Press the 'Set-up' button on the remote control
2. Select the 'System Info' mode from the on-screen menu
3. Using the remote control 10-key type in '1101'
4. 'Region code' should appear as an option on the 'System Info' menu. Initially the region code will be set to 4 (depending on your country). Press '0' on your remote control using the 10-keys to set to multi-region.
5. Press 'OK/Enter' on the remote control.
6. Finish by pressing the 'Set-up' button once more.
Posted on Sep 22, 2008
  • 50 Answers
SOURCE: How to change region code on Toshiba D-VR3 player?
1) In DVD mode,press System Menu.
2) Go down to the Lock icon.
3) While lock is highlighed, press 0 for seven times (o,o,o,o,o,o,o).
4) There will be a pop-up window that asks you to confirm.
5) Press ok.
Jay
Posted on May 21, 2009
SOURCE: Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Posted on Jan 14, 2011
Unlock the dvd code
DVD REGION FREE & BLUE-RAY REGION FREE
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From:-
www.dvdfab.com/products,free.htm
May 29, 2012 | Computers & Internet
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
DVD's that I have palyed before not playing and DVD players says "Region Error"
Your DVD player's Region code has been changed and now it does not match the Region code on thr DVD disc/s.
If you want to play DVD from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From: -
www.dvdidle.com/dvd-region-free.htm
May 30, 2011 | Computers & Internet
Im wondering if anyone know how to turn off the region zone for a Sony DVP-FX750. It was purchased in america with a zone 1 & we have zone 4 in Australia. I've tried to burn a DVD to play, but...
This question is one of my most frequent on FixYa.
There is no "region-free" or "region 0" setting for any DVD player/recorder. Only DVD media can be region free. Every single offer to set a player or recorder to region free that I am familiar with has been a scam. The reason for this is to prevent DVD piracy.
Most DVD players and recorders (SONY included) have provisions for making a maximum of THREE changes to their region code. A fourth attempt at changing the region code will result in the player/recorder being turned into a paperweight.
Bkhopkins- in your case, you will be able to change your region code from region 1 (USA) to region 4 (AUS). Doing so will leave your player with 2 more changes, maximum. Check your manual for the procedure and the exact number of changes you are allowed. Please be aware that after you change to Region 4, any Region 1 DVD's will not be viewable unless you switch back, which will use another of your three changes.
You have an alternative to salvage your DVD's by downloading a program called DVD Shrink. This program is capable of removing the region code from your DVDs and saving them as region-free at the sacrifice of some quality. You will at least the be able to view your US DVD's without sacrificing a region code change on your player.
Good Luck, and Thank You for using FixYa!
May 08, 2011 | Sony DVP-FX750 Portable DVD Player
I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Nov 02, 2010 | Toshiba SDV395 DVD Player/VCR
Message "wrong Region" appears in my Sony DVD -
DVD region is an anti-piracy method to block DVDs from other countrys to be played on a region where that DVD isn't available for selling. You still can watch that DVD by changing the DVD Player region code from options but be aware that you have a limited number of changes, after changes reach 0 you cannot change DVD region code anymore and your DVD player will be stucked to a certain region that you selected.
Nov 02, 2010 | Sony DVPFX810 Portable DVD Player
Unlocking sharp dvd dv-slv8 for indian region
DVD drives region settings can be changed to view DVDs from different region, but on the 4th change the DVD player will lock on the 4th region change.
The DVD player can be made region free by upgrading the firmware, if it is available, but if you make a mistake the the DVD player will be a piece of junk.
The best way to make a DVD player region free is to install a piece of software on the computer to make the DVD player region free.
Please click on this link and follow my instructions to make the DVD player region free :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Jun 20, 2010 | Sharp Cell Phones
Region changing
Make your dvd player region free like this:
It works for NS50P, NS575 and the most models of the families NS50 e
NS500.
With the DVD player turned off(stand by), press:
TOP MENU
CLEAR
POWER
Choose option 2 and after option 4. Type:
12450 [press enter]
00000 - Then press enter and power off.
DVD will now be region Free.
Feb 22, 2009 | Sony DVP-NS50P DVD Player
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Apr 27, 2007 | Philips DVD 622 DVD Player
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
