Metrik MDD-T64 Car DVD Player Logo
Posted on Feb 08, 2010
If the display screen turns white but music is still playing how do we get the screen to come back on so we can see the radio features?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
2049
Points
14
U cant that means the screen went out
1helpful
2answers
Ford territory audio display screen is playing music but gets blank in 5 seconds but when i touch it again displays
Mine did this after kids played with it, just hold the power/volume button pressed down for a few seconds and it will go back to normal.
When I turn the radio on its plays fine for about five seconds, then it's stops playing and it says call on the screen. Then if I hit the power button again it goes back to playing music and it never
Is your Bluetooth devices connecting to it automatically when you turn it on? That is most likely the reason, your getting into the car, turning the radio on, playing music and then your phone is connecting to it automatically through Bluetooth, causing it to cut out the radio and display "Call".
Were to find fm radio and does it rely on internet for said service. Thanks Nigel
FM radio in the Defy comes bundled in the music player. Firstly, connect the wired headset, because it will act both for listening to the FM radio, and as as the FM antenna itself. Ok, either go to its icon, (in the 6th home screen), or go to 'Start (the circle in all the home screens) > Music'. Then, if the last music you played comes up, press 'Menu > Music Home'.
Before you click on 'Radio', on the home screen, if you are worried about data usage, be warned that it will occur if you want lyrics to be shown as music is being played. If you want that feature, but don't want to use your carrier's data plan, you can turn your phone's Wi-Fi on, and connect to either your home network or a plublic access point. If you need further informations on how to do it, please, let me know. To turn this feature off, go to 'Menu > Settings > Display lyrics' and make sure that 'Show lyrics in player' is unchecked. Press the back button, then 'Data Usage', where you'll find checkboxes for 'Download song data' and 'WiFi only purchasing'. Set them accordingly. Press the back button twice, then 'Radio'. You are now listening to the FM tuner. After finishing, press the back button until you reach any of the home screens.
You'll notice that the embedded FM player is able to play sound on the wired headset only. It this is if fine for you, we're done here. Neverteless, this standalone application (many thanks to yipyipyip) doesn't even require that the wired headset be plugged in, at all. If you are not subscribed to xda-devs, do it. Download link in the first post. Download it and copy it to anywhere on your phone (e.g. sdcard). Then, go to 'Menu > Settings Applications', and make sure that 'Unknown sources' is checked. Press the back button twice to finish. Now, go to 'Start > File Manager > Memory card', and navigate to the apk file you have downloaded. Click over it, and you will be prompted to install it. Then, go to 'Start > FM radio' and have fun!
Regards, Carlos
3helpful
How do I turn the shuffle feature off?
On the iRiver Clix
  1. while playing music press and hold [Right] for displaying the additional features.
  2. select Play Mode with up / down for going into the playing mode
  3. press right for entering the Play Mode menu
  4. change Play Mode with up / down
note
The Smart Key on the right side of the player can also be assigned as
Play Mode switch for shuffle on / off. The Smart Key can be set in the Settings of the player.
for going into settings press right on the display
for selecting an item in settings, e.g. Smart Key, use the screen's edges up / down
press right in the screen, when Smart Key selected, for going into changing Smart Key function
press up / down for changing the Smart Key function
repeatedly press left in the screen for going back to the top menu
Screen is all white
the display screen is faulty have an expert change it for you
2helpful
Comdial impact 8024s speaker button turns on after a few seconds automatically.
You have the back ground music feature turned on . If you had a radio connected to the system you would here music playing .just turn off the feature or email me at efren [email protected] and I will look up the code if you do not have a feature book .
3helpful
3answers
Abt transcend tsonic840
Introduction
Combining a mirrored surface and metal body, Transcend’s MP840 catches people’s eyes. This new MP3 player is easy to carry because of its compact size (82mm long x 40.5mm wide x 12.5mm deep) and light weight (70g with battery). The 1.8-inch color TFT-LCD screen with high resolution (176 x 220 pixels), which delivers the best image quality, is especially designed for video and photo playback. The 3-phase wheel is easy to use and the brilliant graphic user interface displays clearly through the shiny screen.
As a portable multimedia center, the MP840 supports many audio and video formats such as MTV, JPG, BMP, MP3, WMA, WMA-DRM10, and WAV. This allows you to enjoy your favorite videos, music, or photos. In addition, you can read e-books with the MP840. It features a lyrics display, and is equipped with 7 equalizer effects that include a customizable USER EQ mode for you to create your own music style. With a fully charged battery, the MP840 supports up to 30 hours of continuous playback, so you can enjoy music all day.
The versatile MP840 is not just a portable entertainment center, but also provides many useful functions such as digital voice recorder, FM radio, FM recorder, real time clock to display world times, and has a 13-language interface. The language-learning feature, with adjustable playing speed and A-B repeat function, helps you learn foreign languages in an effective way. The built-in Hi-Speed USB 2.0 connector provides quick charging and data transferring. MP840 is now available in two capacities: 2GB (Glacier White) and 4GB (Mystery Black).
Features
- 1.8-inch (176 x 220 pixel) Super Color LCD Display for Playing Videos and Photos
- Plays Music, Video (.mtv) and Photos (.jpg, .bmp)
- MP3 Player supports MP3, WMA, WMA-DRM10 (subscription music) and WAV music formats
- FM Radio (FM Radio recording and the ability to preset 20 FM radio stations)
- Advanced Digital Voice Recorder
- Ability to read E-books (.txt)
- Karaoke-type lyrics display
- VAD (Voice Activation Detection), Very High quality Gapless Audio Recordings
- A-B repeat function allows you to continuously replay a designated section of a track
- Variable Track Playback speeds
- Supports 13 user languages including song/artist name display
(English, German, French, Japanese, Korean, Greek, Russian, Spanish, Italian, Portuguese, Turkish, Simple Chinese, Traditional Chinese)
- USB Flash Drive capabilities for data transfer and storage
- Included Software can be used to Lock your computer and setup Passwords for your files
- 7 Equalizer effects, including a customizable USER EQ setting
- Powered using a rechargeable Li-ion battery (fully charged battery supports over 30 hours of
continuous music operation) *
- Hi-Speed Mini USB 2.0 port for easy computer connectivity and fast file transfers
- Real Time Clock (RTC) displays local and world times
- Sleep Mode, preset the player to Auto-Power OFF after 15, 30, or 60 minutes
- Automatic screen saver runs if the unit is idle for more than a few seconds, this acts as a battery saving measure
hope this info helps u....
1helpful
N70 White display
its about display connector.follow display wires & try to fix the connectors
2helpful
2answers
W300i phone displays white screen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
It won't let me play my music!
no worries. there may be a read error. if it still connects to your computer fine download all of the files, movies, mp3, mp4 etc back onto your computer. once you have done this go into the file holding all of the mp3's and set the file to show details and look for a mp3 that is the incorrect file size... in general comparison to the other files. also if the device came with software look around for a restore factory settings button or wizard, and once the device is completely clear restart it and reload the files back onto it, remove the device (safely) then switch it off and back on and then try it out again. hope things work out bro.
Top Metrik Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
