The most common cause of checksum errors in CMOS is a battery that is losing its power. You should pull the cmos battery and check its voltage with a volt meter. (It should read no less than 2.6 volts DC though 3.0 is recommended). Or just replace the cmos battery altogether. Viruses can also affect CMOS settings.
After checking the cmos voltage and or replacement of the cmos and while the system is powered down. Remove the system memory for about 1 minute. Doing this will remove any possible memory resident virus’s.
Download Western Digitals; Data Lifeguard Diagnostic for DOS (Floppy) or Data Lifeguard Diagnostic for DOS (CD)
WD's web site;
http://support.wdc.com/product/download.asp?modelno=WD1600AAJB&x=6&y=7
Use this software to setup you're hard disk drive.
You can also test the drive for errors and much more. Both of the above, floppy or CD are bootable and work in DOS mode. (Keep in mind all data will be erased). This is the best way to setup you’re hard disk drive before installing windows on it.
Cheers'
Mike
