Jenn-Air JXT8136ADS Kitchen Hood Logo
Posted on Feb 07, 2010
NEED HELP REPLACINT FILTERS
WHERE DO FIND REPLACEMENT FOR FILTERS. I AM LOOKING FOR IT TO REPLACE WITH BAFFLE FILTERS.
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
3157
Points
20
Contact Dave at
Metal Filters
Filter Factory TTN Inc
They mfg filters.
1helpful
How to replace baffle inside tumbler
some baffles have a screw at the far end inside the drum. remove screw and push baffle to remove. If you dont have that type of baffle then you would have to open the top cover and tilt back. You will be able to see the screws that hold the baffles. some tops have screws in the back to remove top. Some have clips in the front that would need to be push in with a small spatula. Good luck. I dont know if your able to post pictures with your question, it would really help.
1helpful
Will drilling holes in the stock pipes baffles cause any harm
Not at all Patrick. Just keep in mind that you do want
some back pressure and not all out "straight pipes" of
course....so start small. I'd say roughly 3/8".
And since I don't know the length of your baffle, I can't say
how many to drill.-but I have done this for a friend that was in need of help and I created my own baffle for him and it turned out great.
But in your case ,-Hypothetically speaking Let's say the baffle was
12" long...I would drill 3/8" holes, straight through and alternate
meaning sideways...then the next straight down. And I would drill every 3 inches.
I'm Guessing your looking for a 'lil more power and performance
and if you do it right, you can also increase the fuel mileage.
Please let me know how everything turns out, and on top of that,
Don't be afraid to first Build an exact copy of your baffle so
you can interchange " creations " till you get what you're looking
for.
Remember...the more exhaust that can escape the cylinder,
will help Pull more air and fuel into the cylinder.
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
Primary Filter
Exhaust Foam Filter
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
Primary Filter
Exhaust Foam Filter
Hope this helps!
2answers
Im at the six month point, red light flashing, which of the filters do i replace and do i need to sanitize the storage tank?
The filters that you should replace every the six months are the two pre/post filters (FQROPF). The membrane (FQROMF) needs to be replaced every 1 to 2 years. During the filter change, bacteria could be introduced, so it is recommended that you sanitize the tank while changing the filters. Here are the filters you need to replace:
http://www.freshwatersystems.com/p-7787-ge-profile-fqropf-smartwater-ro-pre-and-post-filter-set.aspx
1helpful
REPLACEMENT FILTERS
Hi
here you go
http://www.delonghi.com.au/company/contact_us.asp
Please leave feedback
Front Door Seal/Baffle Replacement
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
2answers
Coin stuck in the tub baffle
on top of the machine where the filter is there are 2 screws`remove.gently pry up on the top front of machine.it should pop up. rotate tub till your coin gets to the top .you should see the screws you need to remove .
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
